Hey - did you manage to test this out yet? I'd be interested to see if you get past ~950mB/sec that way..
Having both SAS wide cables connected to the expander appears to have ZERO effect.
No, I didn't use 2 cables as the labels on the enclosure says one of the "In", and the other is "Out". I had assumed it's for daisy-chaining. Let me know if this assumption is wrong.
The 500MB/s limit was due to my pci-e bus. I had it at a physically 8x slot, but actually only runs at 4x. I moved the card to another slot (16x physical runs at 8x), and got a speed improvement to 650MB/s. I was hoping for a 2x improvement, but looks like only a 30% improvement. Looks like I now need to hunt for a different system/motherboard that has PCI-E 2.0.
Can the expander in this be replaced with a 6Gb/s expander? If so, which model would fit?
I'll still on the fence about getting one of these due to the performance numbers, but I do love the number of drives it can present.
I believe the problem with be powering the expander. Then 6G Chenbro expanders may fit physically, but it depends on the PSU outputs if you could connect it.. Same thing with the HP expanders.
May I ask - why do you need 6G? You're never really going to need more than the 800mB/sec people are seeing... and once you use it in 'real world' cases, you probably won't even hit 800mB/sec the same anyway..
The only time it would matter is if you were daisy chaining a bunch together... but if you were doing that, you would have to be using 6G drives.. and if you can afford 48+ 6G drives for storage.. I think you can afford more than $300 on a chassis..
OK, Got my chassis hooked up. Since i run my boxes in the storage closet in my room it is quite loud. would it mess with the firmware if i ran some quieter (but larger, cut out room for 140MM fans) slower RPM fans? those 80MM delta fans scream :s
Good question, and I guess the only valid answer is to determine whether the drive cage can really be upgraded going forward or not. I am looking to throw some SSDs in there for our SQL boxes at some point since the MD3000i doesn't support any SSD devices but even then we really will not be saturating any connections anyway.
Crikey! that site has excellent prices on SAS cables, just bookmarked it. thnx!!
I've ordered 8 SFF 8087 to SFF 8088 cables from ebay merchant discussed here a few days ago...$26 a piece seems like a great deal...of course they are coming from Hong Kong so who knows how long that'll take.
I also broke down and bought an LSI SAS6160 SAS2 Switch...I'll temporary disconnect the drives from the SAS expander in these enclosures and wire the drives directly to 8 ports on the SAS6160 (which will negoitiate to 3Gbps). Then my OI server will connect to the SAS switch via 2 6Gbps wide ports on the switch.
I'm hoping that by eliminating the SAS expander, my LSI HBA and LSI Sas switch will now do SAS multiplexing and I'll be able to pump upwards of 4000MB/s.
I'm probably just dreaming.
Wondering if you had a chance to test this yet and if so, what the results were?
They list it as having Two external 6Gb/s SAS 2x wide ports on the products page:
http://www.sgi.com/products/storage/jbod/1116.html
Odd.
The enclosure in question is not what you've listed. We're working with the SE3016 which is the older brother of the one you've posted.
