Why are you adding these huge links that have nothing to do with the topic??
Also hey! It's on topic! Xeon 8175 is 8th gen technically, Kaby Lake R and Cannonlake (10nm product) are too!
Because he is better at being "special". He told me so.I did not understand the reason for the Xeon 8175 link.
My bad!!That was private! I trusted you
Infinity fabric is a massive bottleneck. But if you chose to use applications that scales extremely well and doesn't have any main threads. Then you dont see it as an issue (CB uses tile based render). That's why companies with weak interconnect likes to demo these. There is a reason why you can run faster by disabling a cluster or increase the infinity fabric. Just look at EPYC, there are more latency on a single EPYC chip than a 4 node Xeon. And one of the reasons why EPYC have sold 100-200 chips and Xeons have sold 1M+
There is a reason why Ryzen already got huge price cuts and more to come. And then we dont have to talk about the RMA hell and bugs that plaque Ryzen with machine halts and data corruption because someone skipped close to a year of QA.
Why is the price everywhere for 8700k $414? I thought MSRP was projected to be $359.99? Seems bogus. This doesn't happen in other product markets. I don't want to pay a $55 markup when Intel said it was gonna cost less. When will it settle down to the originally projected price?
How much does screen size matter in comparing Ryzen Mobile and Kaby Lake-R battery life? - The Tech Report
TL : DR
KBL R is 2.4x~ better on external screens with a smaller battery.
Intel 10nm is better than everyone thinks - Fudzilla
TL : DR
According to Fudzilla's "well placed sources" Intel's 10nm is in good health and ready for mass production - HOWEVER they are waiting for even higher yields to maximize profits on the node. Basically arguing economics
Its not. Just check more stores
Your right, It's not:
Paper Launch
That's all fine and good and I don't have a problem with not using solder in theory...
BUT...
Why is it then that a $30 3d printed delid tool with a little thermal paste can lower temps 10-20C over Intel's stock configuration?
The 1920x gets 1.094 using this graph and your formula, so it is clear PCPEr used garbage Ram/bios for this. That is an 18% difference now.
I've seen Ryzen get over 1800 on CB which puts it in the same IPC as SKL-X such as the 7800x running 4.8 ghz (easy comparison - both 8 core)
What is ADF?
IDF is the Isreal Defense Force.
Maybe ATF - AMD Targeting Force?
I just assumed CineBench was the most popular synthetic, but if it really favors AMD the most, that might explain why I see it getting thrown around everywhere.
I miss my threadripper but NOT for gaming in the least.
My 8600k is hitting 202 single thread in cinebench since were referencing CBench. 7820x is hitting like 198.
The difference is nil. It is just MUCH less expensive if all you need is gaming to go with 8x00k chips. But I need horsepower for other tasks not just gaming hence x299 is for me.
I promise if you sit aroind and gasp at a $50 dollar premium but you can snag a chip your missing out. Coffee Lake IS THE GAMERS chip hands down.
Forgot to add...
Edit... my 8600k is faster at single threaded work than the 8700k was and at a lower clock speed. I cant answer why but it could have something to so with SMT adding latency as the chip decides what thread is assigned to what core during the workload. I.e. single thread operation doesnt mean its start to finish on the same one core the whole time the job will bounce around the chip all over the place.
Its been used for years to show IPC improvements at the same clock speeds since it uses the same extensions. The only thing that might effect it some now is the growing size of the cpu cache. AMD does better in multithreading then Intel and that is why it tends to score better. Some programs leverage different instructions and close that gap and then you factor in the clock speed advantage Intel has as well. It's just a metric like any other program it's just used as a good bench since it has not been continually optimized. Most programs are optimized for Intel and not AMD so this a program that gives a more clear look at the IPC of each company.
Yet they dont perform the same. So you can see how pointless it is.
Ok only difference for me is 3000mhz CAS 15, was just curious4.8 ghz on the 8600K I5. 4.8 on my 7920x 3000mhz ram @ cas 16 on the 7820x and 3200mhz @ 16 on the CoffeeLake.
Cache on 7820x is 3ghz
Windows 10 64. I am not benching with a clean install and nothing running. I have all kinds of shit running so my scores are going to naturally lower than a fresh install bench right away. That is how it should be... realistic usage not a clean install with nil running as background processes.
so basically if amd fix up their infinity fabric issue they are good to go right? ryzen 2/3 show us what you can do thanks.
No not at all ... the 7820x might have a bacteria sized difference in single threaded performance but the 7820x absolutely CRUSHES Coffee Lake in everything else except raw high end clock speed and even that makes no difference in the much much higher overall performance and throughput of the 7820x and higher chips.
Hint: Delidding.
No. The 1920x gets 1.035, which is virtually identical to the 1.025 got by RyZen. The difference is less than 1%.
i7-8700K
IPC = (1/3032.11) / (6C * 4.3GHz) = 1.278 * 10^(-5)
R7-1800X
IPC = (1/3297.1) / (8C * 3.7GHz) = 1.025 * 10^(-5)
TR-1920X
IPC = (1/2176.58) / (12C * 3.7GHz) = 1.035 * 10^(-5)
So AMD has about 25% lower IPC on Blender.
I have said you twice that Cinebench is an exception, not the rule. CineBench is a favorable case for Zen.
PCPer found that 1800X is 13% faster than 8700k in CB15. This is reduced to 8% on POV-Ray 3.7.1. Reduced to 5% on Handbrake. Tie in X264. And then loses in Blender and Audacity. 1800X is 10% slower in Blender. So CB is a favorable case for RyZen.
And rendering/encoding, which is a kind of task well-suited for the throughput-optimized Zen microarchitecture. On latency workloads the gap is higher and Zen is worse.
That’s why I’m still using my 6700k and laugh at those who recommend ryzen for gaming builds. 6700k/7700k and especially 8700k now are no match for amd in gaming tasks. Simple as it is.I just fired my 8700K system up and played some PUBG. This system is stupid fast compared to my Ryzen setup @ 4.0. Night and day difference running a 1080 Ti. Ridiculous.
Performance
As you'd expect, running six cores at 4.7GHz results in some stellar benchmark results (more so if you can brave 5.0GHz). Even though it has two fewer cores than the Ryzen 1800X (a CPU that costs a hefty £437), the 8700K comes in faster in many production workloads. It's four seconds quicker in Blender at stock, and 11 seconds quicker when overclocked. It's faster at Handbrake video encoding too, and miles ahead in 7-Zip's synthetic benchmark, which tends to favour clock speed even in multithreaded mode.
It's only in PovRay and Cinebench that 1800X comes out on top—and only then by a small amount.
But it does it at a higher price?The reason why RyZen gets good scores on CineBench is because CineBench doesn't represent average real-life performance, not because "AMD does better in multithreading". Even with only six-cores CoffeLake beats 8C Zen in most multithreaded scenarios. From Arstechnica review of CoffeeLake:
Price/performance?
Running 6 cores at 4.7 GHz is overclocked though.
1800x is 319.008700k --> 409€
1800X --> 417€
https://www.pccomponentes.com/intel-core-i7-8700k-37ghz-box
https://www.pccomponentes.com/amd-ryzen-7-1800x-40ghz-sin-disipador
That is like pretending that XFR in Zen is overclocking.
Overclocking is when reviewers and users push the clocks on the Infinity Fabric interconnect via overclocking RAM to 3200MHz and higher on Zen systems.
1800x is 319.00
8700k is 414.00
Newegg.com
