Shintai
- Jul 1, 2016
well lets see, 8 cores is 33.3% more cores than 6 cores. 8700k assuming it can hit 5ghz at 6 cores and 1800x can hit 4ghz at 8 cores, intel's frequency is about 25% higher. intel has about 6% IPC advantage over ryzen so overall ryzen should still have an edge in multi threaded scenarios in ideal situation.
of course we know real world ideal situation dont exist, CB15 is very close as it is well optimized and scales perfectly with ryzen cpu but more cores means worse scaling so 6c each core efficiency should be better than each cores in 8, unless CCX design says otherwise.
but yes i agree 6c 5ghz will come VERY CLOSE to 8c at 4ghz ryzen in multi threaded scenarios. in ST it'll just blow ryzen away.
The real IPC is much more than 6%.
