Intel x25-m ssds in a raid0!
ar09
what performance gain will i get by running 2 intel x25-m in a raid0?
In many cases this can be a bad idea.
Trim is a pretty big deal with an SSD in terms of maintaining it's initial performance. You can't use Trim with your drives in Raid.
Trim doesn't matter with G2s that much... there's minimal drop in performance according to Anand. But then, OP didn't state whether he has gen1 or gen2 drives :)
i have the gen1
i begining to feel this is a bad idea. ssds, maybe are not ready for raid...
yeah, g1 is not getting TRIM firmware so it doesn't matter if it's in RAID or not...
SSDs performance deteriorates to around 40% of the drives full potential maximum in most cases. Talking worst case scenario after several months of writes. SSDs scale nearly linear when put in RAID0 arrays making 2x RAID0 SSDs perform to around 80% of a single SSDs full potential at it's worst which is still much faster than a single HDD. With or without TRIM, SSDs are RAID friendly.
That has been my experience with them.
Also keep in mind that many drives are now featured with garbage collection built into the firmware. TRIM is nice in theory but may be obsolete before it even gets it's spotlight. TRIM also has not been properly field tested with the Windows OS yet and may contain more overhead than what many of us are willing to tolerate. I've already seen a lot of issues with it while beta testing TRIM capable firmwares on Win7.
Jason
Did you mean to say that SSD perofrmance deteriorates to 40% of maximum (meaning a drop of 60%)? Or did you mean to say that they lose 40% of performance, resulting in 60% of maximum. Either way, that seems excessive to what most other sources are saying.
There are some SSDs that will drop to 40% of their max performance when the disk is near full capacity and every write requires an erase beforehand due to filled pages. That is the absolute worst case scenario though and nothing close to actual usage. The point was that even in the worst case scenario, RAID is valid.
Jason
I could have sworn I read somewhere recently that the new Intel Matrix drivers allow TRIM to pass through to a RAID array (Win7 only) ... Am I on crack? :confused:
I'll say it another way so there is no confusion. 3x30GB SSDs in RAID0 that get around 450mb/s writes and 600mb/s reads and is 90GB of storage. It cost close to the same as a single 120GB SSD.
At it's worst, the RAID0 array may slow to 200mb/s writes and 450mb/s reads. Still better than the single 120GB SSD at it's maximum specs. 3x30GB array is same price, no maintenance and faster in all scenarios due to the near linear scaling of RAID0. If the SSDs happen to have features such as garbage collection that runs at the firmware level, then deteriation is very minimal and works even in a RAID array, unlike TRIM at the moment.
Jason
