zmjone2992
- Jul 3, 2007
wow, didn't you know you could do sli with the quadro cards. Learn something new every day
new mobo. Ok so Im a little lost here. I know what a 771 socket is but what is an LGA 771 socket they are different since I see that there 2 different series of cpu's also.
FB-DIMMS what a bad choice for a new motherboard.
I have been using them for a year now and do they run hot. And not OC good either.
I have been running 8 banks of them to make them run as fast as possible and still mem only scores a 4.4 with Vista 64. not realy impressed with FB-DIMMS.
Good luck tho with those mobo's, have fun.
wow, didn't you know you could do sli with the quadro cards. Learn something new every day![]()
Dan_D I take it that you had FB-DIMMS @ 800 I ONLY used 667 fb-dimms that is why my 4.4 score all the rest of the scores were 5.9.
The quadro's had SLi first!
Then it got passed down to the consumer market.
I'll assume that your mentioning of '4gb' in this post actually refers to '4 modules' because the test configuration did in fact have 4GB of RAM installed.sorry if this has been covered (didn't feel like reading 6 pages to check) but why doesn't your standard test configuration include 4gb of ram yet? given that you're using vista 64 and also that games are starting to surpass the "2gig barrier", why are you still testing with only 2gb? not to mention how dirt cheap ram is these days and the fact in this article you are DIRECTLY comparing a system with 2gb to a system with 4gb... i'm sure you would find that adding an additional 2gb of ram to the test system would change some of your "real world" gaming benchmarks not just in this review but in many other recent reviews. given that most of us reading your site on windows vista probably have 4gb of ram currently in our systems it would make sense to give us benchmark numbers that we can directly compare to our own systems. at least i thought that was the point to ditching the "canned" benchmarks.
For Gamers?
This would be the biggest waste of cash I could make on my PC.
As a Gaming Enthusiast, nothing I have read about Skulltrail makes me want one.
It has very bad performance / $ and very bad performance / watt, both of which are high on my list of essentials.
It doesnt even offer an increase in performance in any game I play and even loses performance in some!
Incredible given its target market and the cost.
By the time 8 cores will be needed in Games, this will be old tech and superseded by much cheaper and faster hardware.
Anything more than 2 card SLI or Crossfire is of very little benefit so Quad cards are pointless for gaming.
By the time Quad SLI is giving near the performance return we would hope for, there will be newer, cheaper and faster hardware supporting it.
For Encoding, Compression, Rendering etc, I can see its appeal if its your livelihood and time costs money.
As an enthusiast, I would look on this in a few years as a lemon and regret spending so much for so little benefit
As a Gamer, <scratches head>
Those cards are only supported in dual mode and even then, the drivers aren't released to enable CF.Alright, I have to ask...
When are we going to see this bad boy with four Radeon 3870 X2s?![]()
This has been answered several times earlier in the thread.(Oh, and you really should have tested with four FB-DIMMs, it reduces latency, and increases memory bandwidth. It also would have gotten you eight GB of RAM.)
since when is a preview skulltrail board their standard test config?? i was, in fact, talking about their standard test config. please read, then post.I'll assume that your mentioning of '4gb' in this post actually refers to '4 modules' because the test configuration did in fact have 4GB of RAM installed.
Kyle already replied to this but you arrived late to the thread. Intel only provided two FB-DIMM modules and Kyle didn't think it was worthwhile acquiring two more of his own for a 4 module test rig. Why would he need to? As Dan mentioned already, 4 modules would not make any difference in games and they are much more difficult to setup. Moreover, the modules would likely never see another testing again. It is completely pointless from [H]'s perspective and I totally agree having Xeon systems myself.
if your article was ONLY to prove which system was faster then you have a valid point that in some benchmarks the sli board is faster. i thought (perhaps mistakenly) that you guys like giving accurate results. in most reviews i've read, certainly the ones i give most credence to, the test configurations are as similar as possible.First off, the NVIDIA 780i SLI system BEAT the Skulltrail that had more RAM in it. Why? Because the games tested do not use more than 2GB of RAM and the higher speed lower latency memory in the comparison system provided the advantage the 780i SLI system needed to beat the Skulltrail board which uses a faster chipset, and slower RAM.
Come on, you had to be thinking it... Eight CPU cores, eight GPU cores... (Oh, and you really should have tested with four FB-DIMMs, it reduces latency, and increases memory bandwidth. It also would have gotten you eight GB of RAM.)
how can you say ram doesn't improve framerates in games? are you kidding me?
if you take a look at most of the signatures here (including your own, even though you mentioned going back to 2gb) you'll notice most people have 4gb of ram. the only reason i made this post is that i feel since you try and accurately demonstrate "real world" scenarios that maybe the standard test config should be updated.
i've felt this way for a little while but only now decided to ask the question. please don't take this as an attack as i have a great deal of respect for your reviews.
looks to me like ram increases their gaming fps. yes, they used rc2 and yes the gfx card was only 256mb but there was a definite advantage to having 4gb. combine that with the fact that the games they used are nearly 2 years old as well it should be a valid example when comparing to a mature vista and todays games.
W... T... F...
Content creators would look for a board with more RAM slots to run RAM drives on or work with large data sets (Raw movie files and ungodly large photoshop pics etc). And maybe more USB ports to hook up external devices (graphic tablets, what ever strange input devices and lots of external drives to move big files around etc.)
$$$ Gamers would want a board that can do Tri-Fire or CF-X with fast RAM and good OC ability and options.
This monster of a board is a sick joke that seems to combine the worst aspects of gaming and server boards.
Again this board supports up to 16GB of RAM. I don't think it needs more slots. It can also do Crossfire-X which frankly isn't useful at all to the professionals out there. If they are smart they'll be using Quadro's as they out perform their FireGL counterparts in almost every way and the FireGL drivers are horrid. So agian the Crossfire-X support is there for gamers. You can use 4 GPUs with this board. 3-Way SLI support isn't there, but I don't truly know if this is Intel's fault for not using nForce 200 MCPs like NVIDIA says, or if it boils down to NVIDIA reserving 3-Way SLI for thier more high end 680i SLI and 780i SLI chipset based boards.
The things is the $$$ Cards that the ultimate gamers (the target of this board) will buy are dual slot for sure and they will want to stuff the max number of cards in there. With the current layout the max is thus 3 cards. With Tri-SLI a no-go for sure and no words on Tri-Fire they should have scraped the third slot and put some PCI there instead. The 4th can stay for PCI-E IO cards.
Hey Dan
Is it true that with all 4 slots of ddr2 being used it'd perform betteR?
Francois the guy who made skulltrail said that it's easy to buy the 800 mhz fb-dimms and put skulltrail quad channel at 3-3-3-12. If you can really do that on skulltrail on microns, I am seriously impressed.
thats hotFrancois the guy who made skulltrail said that it's easy to buy the 800 mhz fb-dimms and put skulltrail quad channel at 3-3-3-12. If you can really do that on skulltrail on microns, I am seriously impressed.
Although there definitely are certain workstation/server apps that might take advantage of the additional memory bandwidth afforded by quad channel, what you're stating is very true for the vast number of cases. An example which I can relate to you quantitatively is F@H. With 4 FB-DIMMs I saw a corresponding drop of only 10-20 seconds per frame per SMP client. That's nearly negligible when 2 FB-DIMM modules average approximately 14:25 per frame at the same frequency.What I know about the chipset and other boards running quad-channel memory configurations suggests that it would be more than likely, but as I said, I don't think the gains would be huge in games or even many applications.
Such is the case with all halo products. Look at exotic cars produced by large automotive manufacturers. Ex. Ford GT or Audi R8. Who's going to buy these? Nevertheless, they garner a lot of attention for those manufacturers in the hope some of that attention is directed towards their other products.wow this thread has gotten alot of buzz over something most of us aren't going to buy.
For certain things it just doesn't pay to get the extra modules. This motherboard is not being marketed as a server board, and people considering it won't use it as a server, hence the 4 memory slots, hence the single onboard NIC, hence the 4 PCI-E 16X slots, hence the OC BIOS, ad infinitum. There are plenty of 6 and 8-RAM slot boards with all the server goodies onboard like the Asus linked earlier for those who are dissatisfied with the D5400XS should look into. Criticism here is misdirected.
There's onboard sound and PCI-E TV tuners or USB-based solutions...4video card motherboard is asking to be vaporware. All I care about is the dual socket processors. There's no point in having a tri-quad videocard since what am I suppose to do with my soundcard and or with my tv turner card???? All we need is one good highend videocard and that's more than enough.
In any case, there are so many motherboards that could better fit your needs already available and for less money. I could probably list a dozen or more. No need to wait for Skulltrail.
Yes but why would I want to go out and buy another TV Turner card when I already have a good one? Onboard soundcard isn't the same.
What do you mean by many motherboards? Are you talking about dual socket?
The problem with the other dual socket Intel motherboard out there right now is that most don't take DDR2-800. I don't think it's compatible with the latest 45nm Hapertown Xeon chip out right now.
But if you do know some good dual socket motherboards out there, please let me know.
You use multiple TV tuners so that you can record more then one program at the same time, or record one, while watching another live.
There are 9 5400 chipset boards on Newegg that take 800 mhz FB-Dimms and all allow the use of Harpertown processors.
They aren't that cheap and you can't even OC your cpu with these boards.
And you think Skulltrail will be cheap?
I would probably buy the skulltrail if it's around $600. The only thing that will be holding me back are the extra PCIe16 slots. No point of buying an expensive server board when you can't OC it.
I don't know why the extra PCIe x16 slots would put anyone off. That is the feature that interests me the most about the D5400XS board. I can make use of at least three of the PCIe x16 slot. Two 8800GTX's and a PCIe RAID controller to be specific.
You are missing the point of what server boards are supposed to be used for. Server boards used for server systems don't need to be overclocked. However the D5400XS is a enthusiast board built on server technology. It just happens to overclock poorly on its' own.
I'd rather have PCIX slot honestly.
To me this seems like a gaming+work system, I'd be interested in that, but lack of PCIX kills it for me. I could live without that if it wasn't for the FB memory.
