Intel Shatters Internet Protocol "iSCSI" Storage Records
HardOCP News
[H] News
Intel has announced remarkable iSCSI performance results that were achieved using Intel® 82599 10 Gigabit Ethernet Controller-based server adapters, Intel Xeon processor 5500-series based servers, and the native iSCSI support in Windows Server 2008 R2. The 1,030,000 IOPS test result is more than double any previously announced iSCSI performance, showing that high performance networking is possible using iSCSI on 10GbE. Could iSCSI be the future of Enterprise storage networking? Learn more about these iSCSI results on the Intel server blog and view the Intel-Microsoft webcast.
One of the problems I remember with this is the unconfidential transactions with iSCSI. The way this guy (http://it.toolbox.com/blogs/database-soup/the-problem-with-iscsi-30602) makes its sound, is iSCSI is not reliable enough with disk reading / transfer rates to make a huge difference when the iSCSI itself is alot of money to implement in the first place. He sites driver problems, but hose can be fixed. I think the main reason Iratus says No is possibly because its not as practical as you would think. The iSCSI is writting faster than the client can read over the IP protocol.
^ those can be fixed* (edit)
Also any other thoughts ? I would love to have an experienced iSCSI member here elaborate.
I have virtualized servers over 1gbe iscsi storage and had no problems with performance at about 100 megabytes per second read and write per nic. Add a few nics and performance is fine. 10gbe should provide nearly 1000megabytes per second and it looks as over 1 million iops. I see no problem with that!
What if your target physical server had a solid state drive as the os, and the iscsi was a secondary mapped drive say d:\ . Assuming you had a sql server or exchange database mapped to the d:\ drive would you not have adequate performance for a fairly intensive application read writes?
On a second note if you are running server 2003 do any of you guys know of a good application to actually serve up the iscsi targets. I am currently looking at deploying this kind of solution for our local network and the best option I have come up with is a solution from Kernsafe.
Thanks
iSCSI. Commonly referred to by vendors as "i Still Can't Sell It"
Lack of guaranteed delivery and an inability to support out of order delivery meant that a missed packet (happens a lot more than you'd think) could stop I/O operations for up to 30 seconds or so whilst it goes through the retransmission and catches up.
Another one of the problems that existed historically was that iSCSI binds as a single stream, because it did that you couldn't load balance it for greater throughput. Now I understand that VSphere 4 on Netapps has gotten round that now so that's one problem gone, similarly widespread 10 gig adaptors will help, but there's still a large cost impact with this.
If you've got sufficient cache in your enterprise storage array then for OS an SSD wouldn't make a massive amount of difference as you'd run it over iscsi/fc for portability and just use local disks for paging if you need it. Where they provide the biggest advantage is for high throughput database systems and the like, it's not as common a use case as storage vendors would have you believe.
I can see a situation where iSCSI is an SME type solution and then converged adaptors (TCP/IP and Fibre Channel running through a single 10+Gig ethernet adaptor) take the enterprise space
