scharfshutze009
- May 22, 2010
I'm doing this for fun.
Does anyone know the correct jumper settings for this processor on the Amptron DX-9700 m919v3 motherboard?
Its an Intel Pentium Overdrive Processor model BOXPODP5V3 aka P24T and is rated at 83MHz. I've tried looking for the jumper settings form here http://motherboards.mbarron.net/index.html but they just don't list it in the jumper manual.
Here are the motherboard specs
CPU
Supports 80486/5x86 Processor running at 25 up 133 MHz.
Intel P24D, P24T, DX4(P24C), DX/DX2-SL, 80486DX2/DX/SX.
Cyrix/IBM/Ti/SGS DX/DX2/DX4.
AMD Enhance DX2/DX4
Cyrix/IBM/AMD 5x86.
Architecture
3 PCI Local Bus slots and 4 x 16 bits ISA Bus slots include One 32-bit VL-Bus Master slot.
Cache Memory Slot
128K/256K/512K/1024KB asynchronous SRAM module supported.
System Memory
Use 72-pin SIMM modules x 4 auto banking or 30-pin SIMM modules x 4, 72-pin SIMM x 2 (The 72-pin SIMM modules x 2 should be the same size) in multiple configuration up to128MB using combinations of 256K, 1M, 2M,
4M, 8M, 16M, 32M, 64M SIMM Modules.
I/O SPEC.
2 PCI IDE interface on board support ATA spec.
Support two 16550 compatible enhanced serial port. up to mode 4 IDE interface. Floppy disk interface and, EPP/ECP high performance parallel port function,
System BIOS
Supports Flash ROM, Plug and Play, Green Feature, NCR 810 SCSI BIOS.
CPU
AMD Enhance DX2/DX4
Cyrix/IBM/AMD 5x86.
Architecture
Cache Memory Slot
System Memory
I/O SPEC.
System BIOS
