- Dec 19, 2005
Interested to hear if you get it running. Nice unboxing video...
werent there some tools posted in the other thread to talk to it via a dos box? have you tried that or am I mistaken?
think I was confusing the Phi/Linux stuff from the "prototype" thread.can't recall about that, only the Intel MPSS software
Mine (Revision 1)
Slaventus' Revision 2
Huh, a couple of differences off hand.
Video out ports seems to have been rearranged. DP, DVI and HDMI on your and then DVI, DP and HDMI on Slaventus' board. The Silicon Image (?) chips move accordingly. I have a feeling if you were to look up the Silicon Image part numbers on those chips you'd find that they were just DP -> HDMI active converter chips.
There are a couple of SMD chips near the connector on the upper left. Actually... what it is that connector? Some JTAG or other debugging port or perhaps connector for a genlock board?
There is a spot for a simple two pin connector near the six pin power connector on your board. I can't tell if that is also in Slavantus's board or not due to the blur in the corner. Also both boards have a jump near the 6 pin connector. Any labels near it to identify what it does?
not yetDoes anyone have the drivers for this board yet?
the actual Larrabee card itself has a PC Speaker
A diagnostic piezo buzzer isn't an uncommon feature among video cards, I have many with them.
Very fond memories of my 6800GT, great card.
