Intel Kaby Lake i7-7700K CPU De-Lid & Re-Lid Results @ [H]
WOAH.
I never said anything about failure.
I am talking about drift and degradation.
For example:
If the motherboard displays 1.45 volts and delivers 1.45 volts in 2014.
BUT in 2017 it displays 1.45 volts but actually only outputs 1.43v.
Would you trust a 3 year old never calibrated motherboard and it's related voltage measuring systems, no, you would want it verified with another measurement device.
That's all I'm saying.
Woah, settle down Francis.
sirmonkey1985
[H]ard|DCer of the Month - July 2010
Potato? ;)
1.300v VCORE (Adaptive) highest HWiNFO64 has recorded in the past five days was 1.389 VID, but I had it set to 1.320v in the BIOS and backed off slightly by .02v VCORE in Windows. Using a Corsair H115i for cooling.
It pretty much instantly locks when I set it to 5.2Ghz at 1.35v and I don't want to bump it up much higher.
Having four sticks of DDR4-3466 installed seems to have it running hotter by ~3-8C hotter than two stick of DDR4-3000, but my room is also a bit warmer, so I don't know.
might be memory related then since kyles trying to do 5Ghz with 3.6ghz on the ram. while you're running 3466 and 3000 and being able to hit 5ghz that might be the difference.
WOAH.
For example:
yup i have an old asus board, first year did 1.58v no problem every year that voltage dropped by .2v until the last 3 years where it's gotten worse.. now after 8 years since it was purchased 1.58v set in the bios is actually 1.31v. i was surprised just how fast it degraded though, i figured it would of survived at 1.58v for at least a few years given the board was designed to support up to 225w and my phenom II 940 was no where near that.. i give it maybe another year before it'll no longer be able to supply the required voltage to run that cpu.
Jim Kim
I havent encountered a motherboard that suffers from this.
Yet I've seen many an overclocked CPU that needs more voltage over time.
A single person does not a statistic make. Electronics age, ssd's wear out, capacitors leak, shit happens and VOLTAGES DRIFT.
See sirmonkey1985s post.
And even this example is not enough data to say one way or the other, but it's starting to look like I might be onto something.
or on something;)
Brackle
Old Timer
Holy poop those results....Damn I mean you can almost make a case to say is going cheap or purposely doing that to keep people overclocking too much..
Impressive Kyle. Love that 5.3ghz SS!
Qrash
Am I wrong here or has it only been possible to run at 5.0 and 5.1 after reducing the memory speed? Does this mean the issue was with the CPU's memory controller? I believe the RAM was able to run at full speed when the CPU speed was less than 5 GHz.
Perhaps a future BIOS update or an adjustment of memory related settings can allow the memory to run faster at higher CPU speeds. Or maybe different RAM would run better.
Nenu
[H]ardened
The memory controller does affect overclocks for sure.
ie I cannot get 4.7GHz on my 6700K if my ram is at 3600MHz but it works fine with ram at 3333MHz.
EdKiefer
I have general question, you guys find Asus realbench a good general stability OC test app as its using real app, compared to linx, Prime95 ?
krotch
Thats not how heat works. It doesn't matter that core temps dropped 25%... all that means is that the transfer of the 100+W of heat from the CPU to the cooler (and ultimately the air) is more efficient. That heat will still warm up the air the same amount. The only way to reduce the heat in the room is to reduce the wattage being generated. Changing the TIM has no impact on this... in fact, no cooling system has an impact on this at all. Watercooling would be worse because you are actually adding the wattage of the pump to the amount of power that needs to be dissipated as heat (though it will be small)
Yes, I know that, but I was having an issue getting the heat off the CPU. The stock Intel cooler wasn't enough, the Coolermaster Hyper something rather (I don't remember what it was), couldn't do it. I ended up going watercooling, which was what did it for me. It's possible delidding and keeping the stock cooler or the Coolermaster would have alleviated the issue for me, without resorting to going watercooling. If I was back in my stateside apt, wouldn't have been much issue, as I had A/C. So the cooling setup didn't have to be all the efficient.
krotch
I would like to see the re-lidded processor ran with a standard Cooler Master Hyper 212 air-cooled heatsink just to see if it helps much in that situation as well.
Ya, I'd like to see how the temp differences with regular coolers and stock clock. I got a Kaby Lake on the way, but it'll get watercooled, so I'm not worried about temps with it. I'm staying stock on it, but my old Ivy Bridge will be going back to air, so any temp drops would be good. It was already throttling when it was last on air. I had a room fan blowing on it, while I waited to get my watercooler.
All the random delidding reviews I see are overclocked machines.
CSI_PC
Out of curiosity you tried to combine it with BLK adjustments increase that work better with Skylake and Kaby Lake?
You can do some insane combinations, but curious if it will help in this situation.
Cheers
Nenu
[H]ardened
Cheers
I have barely touched Bclk as there doesnt seem to be a need.
Memory and CPU clock settings are independent of each other on Skylake.
EdKiefer
I feel a 5.0+ghz is a coming :)
The odds should be in your favor now.
CSI_PC
Sort of as the clock frequency is still BLCK x multiplier.
They may be independent but the BLCK influences the clock speed, set it to 115 and see what I mean; the BLCK is now unlinked from the DMI and PCIe.
The difference is that Skylake and and Kaby Lake actually mean you can set this to decent levels where before (unless go quite far back) it was not realistically possible.
There was an article with actual results somewhere that did exactly this for Skylake to show there is a balance between the two and the benefits of a higher BLCK, some have used 150ish in their tests that would be impossible with more recent CPUs from Intel.
Anyway no harm trying is there to set it to 115 and then other settings?
Thanks.
CSI_PC
Here is an article showing it does affect Overclocking.
http://www.anandtech.com/show/9848/bclk-overclocking-intels-non-k-skylake-processors-coming-soon
Although since then Intel has blocked it for anything but K models.
Separate to this as I mentioned is that some tech journalist showed the benefits of using BLCK overclocking along with the multiplier.
One of the top scores in a competition and mentioned in the linked article was Elmor using a BLCK of 152MHz with a I3-6300 that gave him 5.8GHz (on LN2 of course).
Elmor's thread at HWBot: http://forum.hwbot.org/showthread.php?t=149907
Anyway in this instance I am talking about using more marginally say trying 110 to 125 and also with adjusted multiplier that will be needed to assist breaking 5GHz and what is holding it back for some.
Cheers
Nenu
[H]ardened
Cheers
Interesting but I still cant see how it will help.
There wasnt any information that it allows for higher overclocks unless running out of multipliers.
Bclock clocking also allows for finer granularity if you want something inbetween 100MHz steps.
If you still think its worth a go, can you be more explicit why and I'll try. But not just yet as I am temp limited on one core atm.
It appears my CPU die either has a bend or it bends when warm because it loses paste from one end or the other after it has got hot a few times, resulting in 1 or 2 of the 4 cores getting 15 to 20C higher temps after about a day! Pointless to push it harder like this.
I've just bought some Gelid Extreme in a vain hope that the paste will hang around long enough (its quite thick).
CSI_PC
The issue being experienced goes beyond just a multiplier max GHz issue, and I doubt any of us here know or can exactly quantify why the BLCK works well but not necessarily same as the multiplier when done at the extreme comparisons.
It is application dependant if you tried to do an extreme of massive BLCK with low multiplier and then massive multiplier and low BLCK at same total frequency, some respond better than others and it does come down to relationship with memory for some of those apps.
But again I am suggesting a balanced approach to break 5GHz and this would be optimal :)
Look I have given you an article on the subject and also a very good OCer showing it working, if you still are not interested fine as it may or may not help anyway.
Cheers
Reactions: Nenu
Nenu
[H]ardened
Cheers
I had a good go after using Gelid Extreme paste on the core/lid gap.
Basic system: 6700K, Corsair LPX 3000 C15
Tried Bclk at 115 then 151.5MHz (to get almost exactly 4700MHz CPU clock and 3333MHz C16 ram).
115MHz made no difference, the following was 151.5MHz.
Each tried separately: lower CPU voltage, lower RAM voltage, higher cache speed, higher core speed, higher ram speed.
The only change that worked was lower vcore, changed from 1.41V to 1.4V applied in the bios with the same stability.
(reported load Vcore at the CPU reduced from 1.456V to 1.44V)
I cant overclock any higher, even with higher vcore. Maybe 40Mhz but I could do that before.
Cool anyway, slightly less vcore.
ps
Gelid Extreme paste is much better if your core temps start varying compared to each other after delidding.
I applied it a little thick to start with so it could settle to its own thickness all over.
Temps are very uniform, the core that was +15C now matches its neighbor.
Its only a few hours after applying so temps may drop a little as it squeezes out and some variance may still occur.
But it is a stack better than MX-3 or stock white paste for temps between cores not varying which would have been well over 5C by now.
A moment ago I checked all core temps under heavy load and they were within 1C of each other.
I havent seen that before. Even after a fresh paste, the previous best has been 4C difference.
Pleased.
edit
Now next day and temps are still within 1C under load. Would normally have around 10C difference by now on at least 1 core.
Not tested if temps have dropped due to paste movement yet, gotta have similar room temp.
Gelid, great stuff!
noko
Let intel keep their 2 cents saved on tim and i'll keep my $350 and spend it on ryzen. Sick of intels b.s....
Except you might be stepping in another load of BS. Recommend stepping in the one that smells better ;)
noko
Did Intel use crap TIMs to keep CPU cooler manufacturers in business? Or what?
Knowing this I may just crack open my I7 6700K so I can use a much smaller cooler in a SFF system.
sawk
Firstly I have no affiliation with the creator of this product. Nor have I used it.
http://rockitcool.myshopify.com/
This is very similar to the product that was reviewed.
I believe it is based in the US and seems to be as easy to use. This was also on Kickstarter a while back.
The only reason I am mentioning it as the product availability for the Delid-die-Mate 2 is not known and in pre-order only at the moment.
Reactions: noko
Qrash
I saw this product a couple of weeks ago and actually thought it was the one that was used here. I see they also sell relidding parts as well. Thanks for posting.
sawk
You are welcome. I have ordered the Rockit product and the re-lid tool today.
I have a i7-7700k, asus z270 Tuf Mk2, Samsung 960 M.2 drive, Corsair 400Q, Corsair H100i v2, as well as a Corsair HX1000 Platnimum Power supply sitting at home ready to assemble :)
I guess its time to update my Forum Signature.
Reactions: noko
Skyblue
My understanding of Kyle's article is that while delidding will lead to lower temperatures, it wont affect the overclocking limits of the cpu in any meaningful way. In other words, I suppose Intel made a reasonable decision to not spend money that would be completely wasted. While temps are higher at full load, how often is a cpu for home use at full load?
Kyle, next test: Run one cpu delidded at full speed, another nondelidded at full speed, and see how long they last. 5 or 7 years? :)
FrgMstr
Just Plain Mean
Staff member
Promise I won't hose the video....too badly, this time.
Reactions: noko
bal3wolf
Temps don't normaly kill its the vcore so a delided one could run a higher clock while the nondelidded would have to run slower likely to stay under the thottle range or have better cooling.
Peter2k
a drop in 20 degrees is usually the thing people invest into watercooling for
even if it means just staying silent
my 7600k dropped from 88 degrees to 68
under stress testing, on air
that would translate into less noisy fans
especially in more normal cpu load conditions
it's already a K CPU
I'd happily throw another 5 bucks at Intel for not using bad TIM (maybe solder again)
Nenu
[H]ardened
Why did you quote me?
Nenu
[H]ardened
Update:
I noticed my idle temps were a bit higher than normal, ran Prime95 to see if load was also higher and realised its approx 10C higher than I expected, must have missed this.
After a bit of testing I have confirmed that setting exactly the same voltages and speeds, Bclk at 151.75MHz raises my idle temps by 2C to 3C and load by 9C on each core.
ie 1.4V vcore, 4.7GHz core, 4.5GHz cache, 3333MHz ram are the settings used.
I verified Vcore with Asus AIsuite 3 which is one of the only apps that correctly identifies the voltage sent to the cpu.
Vcore at idle is identical for both at 1.424V
Vcore under load is 1.44V for 100MHz Bclk and 1.456V or 1.44V (varies) for 151.75MHz Bclk.
That difference is equivalent to changing from 1.4V applied to 1.41V (at 100MHz Bclk) but it doesnt explain a 9C jump in load temps so something else is happening with higher bclk to make CPU temps jump.
I decided to go back to 100MHz Bclk.
exlink
It's really a shame that Intel decided to use such a shitty TIM. I would understand if they used this for their non-K processors, but they really should've gone a better route for the K line processors which are more geared towards the enthusiast crowd.
Looks like I'll be replacing the TIM with liquid metal once my 7700K comes in and I get my hands on a Delid Die Mate. Thanks for all your research Kyle.
Jayham
Yep, this has further encouraged me to do a delidding/liquid metal on my newly acquired 7700k! Good ole razor method, won't be able reseal but 20-30c temp drop if all goes well is insane!
Hello everyone,
Long time lurker, not many post.
I figured I'd share my results as I was pretty happy with the process and end results thus far.
Relevant System Specs-
Asus ROG Maximus Hero IX
16G GSkill Trident(2x8) @ 3600mhz
7700K
Kracken x62
Relevant changes in bios
Multiplier 50
avx offset 2
Vcore 1.35
Clk - stock @ 100
XMP mem timings
Everything else set to Auto or stock (I think)
The process I went by was to use a bench vice. Set the CPU with pin side facing up. 1 edge of the CPU with the substrate on the face of 1 side of the vice and on the other side at slight angle, the vice catches the bottom edge of the lid. As you can imagine, as you tighten the vice, it "pushes" the CPU away from the lid. Happens fast no muss no fuss. I thought it was really easy and felt no drama or trepidation in doing it. I think the real key is to make sure that both sides of the vice facing into the CPU are clean and flat with no groves to catch on the substrate that would potentially crack or damage the cpu. Cleaning the black goop off was a little harder than I would have liked. I WAS scared of damaging the substrate while scratching that stuff off. I ended up leaving the lid float as I didn't want to re-glue it down this time. I used Noctua thermal compound and suspect I'll probably try liquid metal though based on my results I may not touch it for years....
Onto the results -
I'm seeing max temp at load sitting around 85c on Prime95 v26.6
In Aida64 Stress test, I'm seeing around 78c on avg though I notice when I run that stress test the clockspeed displayed in CPUZ is 4800 instead of 5ghz - I think that has to do with the AVX offset - not sure?
In gaming (BF1) things hover around 70c. Idle is around 36c
The CPU was NOT stable @ same settings before delid, however @ same specs temps were still under 100 at around 92 or so. It was stable @ 4.9. I am not 100% I had the same exact options though so it is possible I changed something else that helped enable 5ghz to be stable after I delided.
Anywho, that's my story for now. Glad that HardOCP has provided so much coverage of this as project to tackle. certainly happy with my results!
damstr
I've been going back and forth between 5GHz and 4.9GHz but settled on 4.9GHz because of 10C peak load temps. See below for more information. Both are perfectly stable
  • 5GHz
  • 1.305v in UEFI
  • 1.312-1.328v in Windows (mostly stays around 1.312v)
  • OCCT S stress test run for an hour and 5 mins. This test is similar to Prime95 in peak temps vs other stress tests
  • Peak temps across all cores from the above test 76/75/75/76
  • Ambient room temp 25C
This is the 4.9Ghz profile I settled on. 10C lower temps and lower voltage. 100MHz isn't worth it IMO
  • 4.9GHz
  • 1.26v in UEFI
  • 1.264 in Windows
  • Peak temps across all cores running the above test 65/66/66/69
  • Abmient room temp 22C
