Intel Kaby Lake i7-7700K CPU De-Lid & Re-Lid Results @ [H]
Discussion in 'Intel Processors' started by FrgMstr, Jan 19, 2017.
  1. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,773
    May 18, 1997
    Intel Kaby Lake i7-7700K CPU De-Lid & Re-Lid Results - Is there any reason at all to take a razor blade, garage workbench vice, or any sort of other tool to your brand new Kaby Lake CPU? Of course there is. That reason being that the Thermal Interface Material used by Intel on its desktop CPUs is pretty much crap...at least to us enthusiasts.
    Etherton, Jayham, Zefram0911 and 9 others like this.
  2. Shotglass01
    Shotglass01 [H]ard|Gawd
    1,917
    Aug 26, 2005
    Awesome! I can't wait to see the TIM shootout as well as the video. Thanks!
    Armenius likes this.
  3. virtualheretic
    virtualheretic Limp Gawd
    237
    Sep 6, 2005
    [H] never disappoints! Im surprised with a 23 degree difference in temperature it still wasnt able to hit 5Ghz. Maybe you need more training? (sorry couldn't resist!) :D
    Im interested in seeing the full fruits of your labor in future article.
    BTW the Discussion link in the article links back to the article itself, not to this forum thread. I had to go to the [H] main page to get to this thread.
  4. phobos512
    phobos512 Limp Gawd
    325
    Jan 5, 2005
    Well, I'll tell you what...I have the exact same situation with my 6700K. No matter what I do it will not be stable above 4.7 GHz. At 4.7 GHz I can throw anything at it and it does just fine; at 4.8 GHz it fails. Depending on voltage it'll boot, but it'll always freeze in any benchmark. Doesn't matter how cool it is, though I admit to not having tried delidding (it's not that important to me). Sometimes you just hit a wall.
  5. Axehandler
    Axehandler Gawd
    635
    Dec 19, 2007
  6. drklu
    drklu 2[H]4U
    2,278
    Jul 15, 2013
    Never seen anyone use rtv to glue to ihs back on, won't the cpu bracket hold on the ihs or is this done so the cpu is stable while installing and removing the cpu?
    Just curious, thanks for the testing, pretty nice decrease in temps for 45 bucks and some time to do it!
    Qrash likes this.
  7. Nenu
    Nenu [H]ardened
    19,088
    Apr 28, 2007
    Nice, thanks for doing this.
    Very similar results to my 6700K delid.
    About 20C drop, can game 100MHz higher but will fail a long stability test.
    ps the link at the end of the article takes you back to the article, not this thread.
    tunatime likes this.
  8. Makeroflostsouls
    Makeroflostsouls 2[H]4U
    2,572
    Jun 4, 2008
    Can't believe it dropped 20c but won't clock any higher. That's a huge drop to not make any difference.
    Dunnlang likes this.
  9. Jim Kim
    Jim Kim 2[H]4U
    3,619
    May 24, 2012
    Excellent article.
    Disappointing results.
    Delidding is a wash.
    Geforcepat likes this.
  10. FrgMstr
    48,773
    May 18, 1997
    Caching issue on the server, trying to figure that out. Thanks for the heads I up though.
    Edit: Should be fixed now.
    virtualheretic likes this.
  11. Burticus
    Burticus [H]ardness Supreme
    4,146
    Nov 7, 2005
    Wow you would think a huge temp drop like that would have more impact. 20c drop is huge. I guess what that tells us is the chips are heat tolerant and if it's not going to hit 5ghz stable lidded, it's not going to be stable delidded either... just cooler?
    Has anyone tried ditching the IHS and using a thin piece of copper instead?
  12. EODetroit
    EODetroit [H]ard|Gawd
    1,485
    Oct 20, 2004
    It meets mine though!
    Ok not really. Nice article, you just used one wrong word.
  13. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,846
    Jan 1, 2008
    I have some real disappoint here with my 7700K running hot due to such a simple bit of negligence on Intel's part. The weak spot of a cooling setup shouldn't be a tiny bit of TIM between the CPU due and the heat spreader. The CPU can push 80C and the water going through the radiator isn't even getting warm.
    travbrad, Armenius, Peter2k and 3 others like this.
  14. Furious_Styles
    Furious_Styles [H]ard|Gawd
    1,515
    Jan 16, 2013
    Delidding only really helps when you are heat limited. I'd personally do it anyway now that I've had experience and am not worried about damaging/destroying the cpu. Like someone else said, sometimes a cpu will only be pushed so far be it a voltage limitation or something else.
    MMitch likes this.
  15. Azrak
    Azrak Gawd
    877
    Oct 4, 2015
    Great article. Short but to the point. Results remind me of NVidia Pascal arch in a way. Lowering temps doesn't help OC as much as it used to.
    actual --> actually
    one to why CPU --> one reason why CPUs
    why --> way
    And already mentioned above:
    meat --> meet
    Guy: I can't wait to meat you! :woot:
    Girl: Ugh... <sigh> :punch:
    Peter2k, nilepez, Nimisys and 2 others like this.
  16. Gideon
    Gideon 2[H]4U
    2,437
    Apr 13, 2006
    The chip is just hitting a speed wall the temperature it's hitting is not the issue. Nice to know a quality paste does make a huge difference in temperature, but that is a lot of money to spend just to make it run cooler not faster.
  17. oROEchimaru
    oROEchimaru [H]ardness Supreme
    4,662
    Jun 1, 2004
    pretty awesome but also wish it was just like this by design... i wonder if other cpus would bernefit from replacing the caps. i bet it would last longer if the cpu was a lower overclock (4.5ghz) and possibly increase the life of the cpu due to lower heat
  18. hurleybird
    hurleybird [H]Lite
    106
    Jan 14, 2012
    Man, I hope Ryzen kicks serious ass when it comes out. Screw Intel and their shitty TIM. They seriously can't spend an extra few pennies to give us something that isn't completely terrible?
    Unter Dog, N4CR, britjh22 and 2 others like this.
  19. gigatexal
    gigatexal [H]ardness Supreme
    7,279
    Jun 22, 2004
    Wtf 25% lower temps and still no 5ghz so disappointed.
  20. motqalden
    motqalden [H]ard|DCOTM Feb 2018, June 2019
    1,360
    Jun 22, 2009
    not sure why everyone is calling this a wash... i would do this just for the temps. with that big of a difference i would bet stock Intel heat sink on delided chip would come pretty close to non delided chip with top of the line air cooler. while this comparison isn't realistic in a real world sense, the point is people pay big bucks to get a couple degree lower temps between the best end air cooling and water cooled setups.
    Armenius, DocSavage, Dwango and 7 others like this.
  21. motqalden
    1,360
    Jun 22, 2009
    And to add to that since my last sentence is slightly confusing. Can you get a higher overclock on this chip with a high end water cooled setup VS a cheap tower cooler like coolermaster hyper 212? l am guessing no, but most people would still go for better cooling just because.
  22. Nenu
    Nenu [H]ardened
    19,088
    Apr 28, 2007
    Its more like 6%, temps start at absolute zero -273.15C.
    But yeah it is still sizeable, bit of a shame.
    ecktt likes this.
  23. FrgMstr
    48,773
    May 18, 1997
    Hehe, fair deal on the Kelvin. I figured since we were using C I should go from zero. But good point, I should actually go from ambient at the time the temps were taken.
    Speedeu4ia likes this.
  24. evilpaul
    evilpaul Limp Gawd
    181
    Dec 31, 2016
    Potato? ;)
    [​IMG]
    1.300v VCORE (Adaptive) highest HWiNFO64 has recorded in the past five days was 1.389 VID, but I had it set to 1.320v in the BIOS and backed off slightly by .02v VCORE in Windows. Using a Corsair H115i for cooling.
    It pretty much instantly locks when I set it to 5.2Ghz at 1.35v and I don't want to bump it up much higher.
    Having four sticks of DDR4-3466 installed seems to have it running hotter by ~3-8C hotter than two stick of DDR4-3000, but my room is also a bit warmer, so I don't know.
  25. thesmokingman
    thesmokingman [H]ardness Supreme
    5,605
    Nov 22, 2008
    Yea, it is not like ppl would ever spend exorbitant amounts of money just to keep their rigs overclocked whilst running cool and quiet. Geeze, who'd ever want to do that?
    Armenius and Peter2k like this.
  26. Corvette
    Corvette [H]ard|Gawd
    1,270
    Sep 12, 2002
    I see your screenshot at 1.368V and 5GHz, but I was wondering if you were able to achieve 4.9 at a lower VCore than without the new TIM
    Also, you said your previous attempts at 5GHz you used 1.35V, does that mean you were able to push more voltage after the de-lid?
    Don't you have 3 more processors sitting around ;)
  27. FrgMstr
    48,773
    May 18, 1997
    Dropped the memory down to 3000MHz and it seems to have gotten stable, will know more tomorrow.
  28. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,556
    Oct 5, 2004
    I can tell you first hand that Solidworks, Premier and several other programs I've used or my clients use can stress a CPU out for hours upon hours at a time. I've seen 12 - 13 - 15 hour Solidwork renders that pound the CPU.
    For a gamer, 2 hours is fine. For a workstation situation, probably not.
  29. grtitan
    grtitan Telemetry is Spying on ME!
    1,266
    Mar 18, 2011
    This!
    Hell, depending on the need, you might be able to have a fanless or super quiet system after a delidd.
  30. TheHobbyist
    TheHobbyist Hugs Hard Johnnies [H]ard
    456
    Apr 8, 2008
    Is there any chance that the function of the temperature sensor has been altered in some way by the process? Is the new temperature value an accurate value?
  31. noko
    noko [H]ardness Supreme
    4,551
    Apr 14, 2010
    I thought the temperature sensors are inside of the die and not on the board - hence the different core temps etc available for reading. So this should not have affected the reliability of the readings unless you broke the die.
    Surprising by a large degree (no pun intended) the difference in temperature obtain! WTF is Intel doing having such crap TIM inside their processor!? - hopefully this light will make Intel, for what ever f___ up reason, to do the right thing and make it right.
    Then seeing the lack of OC ability is also perplexing as well at the end of the day. Looks like 5ghz is the upper wall for Intel at this time with few exceptions.
    I would also try BCLK OCing to see if you can get a better OC. May not apply here but on three separate FX processors the standard fsb would have a ceiling on an OC. Up the fsb, lower the ratio of cpu to fsb, mem speed to fsb etc. brought back stability pushing FX 8120 to 5.2ghz, FX8350 to 4.9ghz and FX 9590 to 5.1ghz.
  32. krotch
    krotch [H]ardness Supreme
    4,509
    Aug 12, 2004
    That's a massive decrease in temps. I'm thinking about de-lidding my proc now. I'm not chasing OC, but I'm always chasing lower temps. German don't ever install A/C in homes/apts, so you're stuck dealing with the heat during the summer months. My system hates that, so I had to go watercooling to keep things down.
    Armenius, alxnet7227 and Peter2k like this.
  33. Xebec_
    Xebec_ n00b
    22
    Jan 13, 2017
    Is the stability test using AVX code?
  34. Peter2k
    Peter2k Limp Gawd
    309
    Apr 25, 2016
    There's a new delidding tool
    comes out at 22.02 at caseking
    it's only 30€, though I hate how caseking adds shipping costs; ehh spoiled from Amazon Prime :D
    anyway the toughest thing when I delidded my kaby lake was applying the liquid metal
    if you're not used to using it (within reason) you better practice just a bit
    but then
    with enough patience it worked fine
    I myself came down from 88 to 68 degrees on an air cooler at 5Ghz
    a drop of 20 degrees is something people usually have to buy a watercooling solution for :rolleyes:
    5.2 spiked up again in heat and voltage
    AiO installed now, needing some time to test :ROFLMAO:
  35. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    I believe so. Kyle's previous OC attempts have always been aiming for "Everything enabled".. That's why he rejected the 5.0 w/o HT enabled OC..
  36. Xebec_
    Xebec_ n00b
    22
    Jan 13, 2017
    Gotcha - so some chance Kyle's chip could run stably at 5.0 GHz in games (which don't appear to use AVX yet) while being limited to 4.9 GHz for transcoding type applications..
  37. Jim Kim
    Jim Kim 2[H]4U
    3,619
    May 24, 2012
    Now that would be funny.
    But I doubt it, although I do miss the days of the external thermocouple machined into the lid. http://www.hardocp.com/image/MTIyNTM4MDczOTdGT2V4YVR6MzdfMV80X2wuanBn
  38. FrgMstr
    48,773
    May 18, 1997
    I think we were the only site to spend the money to do that. :) I remember talking to an Intel engineer about temps on those CPUs. "No real way to get that temp....unless you machined a groove for a thermocouple in there." I thought, well hell, that is pretty easy...and I got out the Dremel. JK, I had a machine shop do it. You could build a jig and do it in the garage though with the Dremel router head though.
    Meeho, Armenius, Qrash and 1 other person like this.
  39. FrgMstr
    48,773
    May 18, 1997
    Yeah, that is the way we do HSF stuff. I will do it that way going forward. I am not going to change the article however. Changing data is never good in this business.
    Here is what the graph looks like scaled from ambient.
  40. Ultima99
    Ultima99 [H]ardness Supreme
    4,890
    Jul 31, 2004
    It's amazing how bad the junk Intel puts in there is.
