Apr 28, 2008 #1 H hk09 Limp Gawd Joined Apr 19, 2008 Messages 192 I am building a new computer and it is my first time. I am wondering do I need to put Arctic Silver 5 Thermal Compound before putting heatsink and fan? Thank you
Apr 28, 2008 #2 Z Zayla74 Weaksauce Joined Apr 26, 2008 Messages 64 It would be incredibly difficult to apply once the HS is installed . So yea, you put it on before seating the HS/Fan
Apr 28, 2008 #3 9 9mmx19 [H]ard|Gawd Joined Aug 6, 2004 Messages 1,556 If youre using the stock fan it already comes with some paste on it so you would have to clean that off first.
Apr 28, 2008 #4 H hk09 Limp Gawd Joined Apr 19, 2008 Messages 192 Is it ok to use the stock thermal compound? Or is it better to use arctic silver 5 thermal compound?
Apr 28, 2008 #5 M Met-AL Supreme [H]ardness Joined Apr 9, 2002 Messages 7,890 Just use the stuff that comes on it already.
