- Dec 19, 2005
“For video editing and motion graphics, the B580 ended up being something of a mixed bag. In LongGOP codecs, it was either the best option or the worst, depending on the specific application and flavor of H.264/HEVC. We expect that, to some extent, this is a bug, but until it is fixed, it is difficult to blanket recommend the B580 for use in this type of workflow. With RAW codecs, we still recommend an NVIDIA GPU. However, the B580 performed great in GPU effects in Premiere Pro, DaVinci Resolve, and After Effects, falling behind only the much more expensive RTX 4070.
In our Unreal Engine benchmark, the B580 was 31% faster than the last-gen A750, and matched the 4060 across the spectrum of resolutions and Ray Tracing. Given the higher VRAM capacity of the B580, it may make for a solid Unreal Engine GPU on the low end. For professionals, it may end up being too low end, though. These results also make us excited to see how it performs in gaming workloads, though you’ll have to check out other reviewers for that.
Overall, the B580 is a terrific budget GPU with plenty of VRAM and solid performance. We haven’t experienced any issues with the drivers in terms of bad installations, OS crashes, or setting wonkiness as we did with the initial Arc Alchemist launch—Intel seems to have ironed out many of the generic driver issues over the last few years. However, we have seen performance issues, particularly with hardware-accelerated media, that we believe to be driver-related. Hopefully, we see a patch in the near future to address those issues.”
Source: https://www.pugetsystems.com/labs/articles/intel-arc-b580-content-creation-review/
