Intel 80gb G1 RAID0, Upgrade advise
Copyright
Ive had my dual Intel 80gb SSD drives in RAID 0 for a while now. Is there any single drive SSD that wont feel like a slow down compared to my current setup? I would really like to get TRIM working. Current setup seems to slow down over time. Hopeing a single drive with TRIM wont be so impacted. Thx for any advise! I know the G3 are coming but wasn't sure what else is out.
A 256GB C300 will more than match a couple 80GB X25-Ms in write speed. But it won't be able to compete on sequential read speeds. I guess you are getting over 400MB/s sequential read on your RAID 0? The C300 will be around 350 MB/s, assuming you have it hooked up to a SATA 6Gbps port.
I'd say wait for the newer generation and stick with the Intel controller. It's faster overall even though the sequential speeds are a little bit worse. IMO, if you're writing enough to the SSDs to make them slow down then you're using them wrong.
[LYL]Homer;1036411570 said:
Thanks for this! I will give them a shot now. What benchmark is the most popular these days? Id like to do some comparisons.
Used CrystalDiskMark 3.0 and went from 486 on fastest read to 514. Driver really seemed to help!
I've had the G1s, G2s, and Vertex2s in RAID0 and I know where you're coming from.
I just sold the G2s for a single Crucial C300 256GB and feel it's a better all around drive.
I'm using a SATA300 port so I'm limited to the 265MB/s of the Intel controller but the increase in other specs/areas makes for a better desktop experience.
Coupled with the avaliability of TRIM and eliminating the hassle of RAID, makes the Crucial drive a no brainer.
I see there are two models of the C300? What is the difference? I believe I am on the 3gb ports with my board.
I think one came with a mounting kit?
Edit...looks like one comes with a cloning/transfer kit.....
The included USB to SATA cable with the EZ Gig II software made the upgrade
Edit2....I have this connected to the SATA300GB/s not a SATA600GB/s slot.
That's probably what I'll end up with if I decide to upgrade from my Intels. I just don't need that much space right now, but the 256GB is the one I'd want since it's the best performer. Maybe the Intel G3s will push the price down. Let us know how it holds up over time; I know at one point the C300s had controller or firmware issues (hopefully resolved now). I just sold a 64GB C300; kinda wish I had kept it for my laptop.
I wouldn't have purchased it if the issue hadn't been resolved. :)
This drive has all the attributes that make SSDs great but it's pricey.
