Omegas
- Jan 19, 2007
I'm considering taking the Dual Core/DDR2/PCI-e plunge and have a setup in mind. Looking for some constructive criticism on where I may be lacking.
CPU AM2 X2 3600+ Brisbane $67
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103046
MoBo XFX 590 (foxcon rebadged) $97
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141001
Ram Crucial 1066 DDR2 2 x 1GB $90 + free 2gb usb flash drive
http://www.newegg.com/Product/Product.aspx?ATT=20148069&CMP=AFC-SlickDeals&Item=N82E16820148069
Vid 8800GTS 640mb ~$300
(need good deal)
The plan is to OC the 3600 to ~2.8 on air with my Zalman 9700. Hopefully the cpu won't bottle neck me at that point. Also, I chose the 640 over the 320 because I'm using a 2407 and would like to run at the native 1920x1200. Not knocking the 320, but have read the 640 really steps up once rez goes above 1640x1050. Also, if YOU were to build this rig and came up with an extra $50, where would you put it?
Will be using this rig to raid in WoW, play some BF2 and possibly Obliv soon along with some NFS.
I've got the OK from the Wifey
for $500 with a 10% swing, so $554 for all this is really close to my max, if not a tad over.
Would love to see some input from the pros, and the rest of you peeps, too. LOL
(need good deal)
