In Ear Vs Over Ear
XAuTomaT1CX
What do you find better in ear or over ear headphones for mobile use not gaming?
i was to buy sony mdr7506 & Zalman Zmic (could use them for gaming too) until I could afford steelseries siberia v2. should I keep with my plan or buy klipsch image s4 and just buy siberia v2 when i can afford them?
If you want something that sounds and works great for mobile use that also does ok for gaming try the $18
MEElectronics M6
I like my MEElec M9P a lot, very solid build and great chord (almost no noise from bouncing it around)... Works great with Android phones, really a great value for how they sound. I'm not sure why you would ever wanna fuss with a separate mic & chord for mobile use...
In ear don't give as much base as the sound gets spurted directly into your ear drum
If it were to be used at home I would go for the over the ear route.
On the other hand if you go around a lot outside of your home then I would go for the in ear route.
+1 for the Meelectronics M6. I bought it when it was $35 1.5 years ago and they still work!
MEElectronics if you just want a cheap pair to use while on the go. If you rather bring headphones along, the Sonys you suggested are very good too. They're durable and are a good price. They also sound amazing (I have a pair of MDR-V6s which is essentially the same thing).
MEElec has a pretty good pair of portable over the ear headphones too (see sig), tho I think Sennheisser's PX200 fold up more compact (if you can find that older model for a good price, I think they're replacing it with a newer version).
thanks for the help guys, I will probaly pick up both the sony mdr v7506 & MEElectronics 6 since there so cheap and durable and it's good to have a spare (Based on 5 pages of amazon reviews) thanks for the help guys
For portability in-ear wins. I have a pair of Shure SE310s that I love. You're not going to get a lot of bass but you get pretty good clarity and the noise-blocking is excellent.
I have the MEE A151s, nothing to complain about. It came with plenty of tips. Also dig it because of the balanced armatures and nicely braided cables.
Great choices! You can't go wrong with those :D
