VanGoghComplex
- Apr 5, 2016
I have on order a custom bracket to properly install the new 480mm rad. It's taking a bit longer to fab than the shop expected it would. I also have on order proper e-Loop fans and more Phanteks Halos to go with them, but I can't be assed to wait for those. I've got a brand new Oculus and a system that needs to be running so I can use it.
Lacking any sense of propriety, decency, or decorum, I've "installed" the rad using - yep - COMMAND STRIPS to the top of my case.
Lo and behold:
Command strips, temped-in soft tubing. Running Mayhem's PT2 right now, will actually start the beast up with distilled tomorrow night. I'll mix up a fresh batch of Mayhem's pastel white when I get the bracket and do the install for real. I'm really excited to see what practically doubling the rad capacity will do for me in terms of noise and cooling. This will be the first "properly" radded system I've run.
Lo and behold:
