- Oct 19, 2004
Interesting. I've been using the zpool gui miner and seeing skein a lot. Will see what disabling it does.
This mornings numbers for undervolted for a 1080TI (this is an 8 card 1080TI rig):
This mornings numbers for undervolted for 1080TI:
IronMan_74
Pick two or three pools, otherwise it take too long to get to the minimums. You are correct on what I'm doing, but I don't have the answer on whether it's routeinly more profitable or not because I just started doing it in the last month, and I'm still fighting occasional stability issues, and mining profits haven't been steady enough day to day to even figure it out with my casual mannerisms. If crypto is doing well nicehash seems about as profitable as any of them - or even higher for some reason, but when you experience a tough day like yesterday - AwesomeMiner and a pool can make for better profits. There are too many moving variables for me to have a good handle on it yet.
Right now I've only selected ahashpool, mph, and nicehash. I've used zpool, and hashrefinery in the past from the awesomeminer options. I like MPH, because I can mine to a specific coin, I enabled ahashpool because for whatever reason, they seem to at least show the highest payouts lately. Whether or not they are legit or not - I don't know. I just started mining with them a day or two ago.
Since I'm still trying to get a feel for all this, I have nicehash running on two rigs, and awesome miner running on two rigs. Not that it helps me because all four rigs have different amounts of cards. (2 1080TI, 12 1060, 6 1080TI, 8 1080TI)
yes - It would be interesting...Archaea
I have 2 identical rigs with 9x 1080Ti's each. As an experiment, perhaps I could let one loose on Awesome Miner on mph, and create a new NiceHash account for the other one, and let them go head to head for a while to see which one does better? I'm very new to Awesome Miner, so it would probably take me some time to get everything worked out on that rig. My main Awesome Miner install is on a workstation that doesn't mine (just monitor all rigs), so I would be installing the client on the 9x1080Ti rig and get the 2 talking together. Might be worth the trouble?
IronMan_74
I'm not sure I know what I'm doing, but I use 30 minutes or 10% as my threshold to switch. Switching too often seems to lead to instability.
Along the way - I've disabled some of the really volatile profit coins. If I happen upon the machine and see it's making $6 a day with 8, 1080TI then I'll disable that algorithm. That's nonsense, and I dont' need to be mining it for 20 minutes way down low because it happened to be super high for 3 minutes when my 30 minute check rolled around.
Just the newest Nvidia driver installed. (Not windows auto update install)idk how you get such high numbers. I am getting 73MH/s for nist5 on nicehash 1.8.1.5. What driver are you using?
Are the ram chips different on your cards?
guys, two different algos. don't compare nist5 hashrates with blake2s hashrates.
Derfnofred I feel the numbers would work out for you. Maxwell-spec cards are still decent performers in the hash/watt category with appropriate tuning.
Personally, i would be hesitant paying that type of price for older gen cards.
I've noticed it's temporarily hanging my system (or maybe just just the dispaly) when it switches to it.Anyone else having trouble with skunk today? I checked a couple of times and it was sitting at 0 on nicehash. Disabled it and everything is mining neoscrypt right now
I have tagged my 1070 / 1070 Ti's to the NH equihash endpoint and what AM tells me i'm making is pretty close to what i actually get from NH.
Why in the world would you risk running a shitty Rosewill PSU? Especially when you need 1500W of power. Get a good Seasonic/Thermaltake/EVGA. Rosewill make cheap shitty generic stuff.Just finished assembling my gpu insert for my rosewill case. Got everything buttoned up and went to install my new rosewill 1500w power supply. Well, turns out it isn't new. Opened the bag of cables and both sata cables are taped together with painters tape that says "BAD". Guess I have to wait a few more days to get a new one.
because it came highly reviewed by johnnyguru
I highly not recommend using a cheap generic part for a system-critical one. Use good/great quality components in critical spots, such as PSUs.
