Hey guys!
I know you've been bashing me for being dumb about cutting heat pipes, and yes, it was pretty stupid.
But I took your advice, got a new heatsink (CNPS10x Flex), and my idle temps are now at 48±2 ºC.
This definitely makes me feel much safer, but, is it still too high? I have two 120mm fans pushing air through the heatsink.
Any input is greatly appreciated!
-Ryan
Hey guys!
-Ryan
I also see NO entrance fans. You need ONE of those too, at least.
Same with exhaust fans; not really any place to put them without a hack.
That's 72C with no OC.
Yeah buy another rack mount case so you have the same problem. Then send me one, just because I'm a nice guy.
Get the Cooler Master HAF full tower. Best case out there.
the 800D would like a word with you
Do a blow hole mod. You can put a fan protector on the fan and when mounted will look like it came from the factory like that. You're good with hacksaws-just joking.
Just get another case. Cheap fix.
I do like that case though. It's neat looking, just not really a computer case.
OK the 800D is 300.00
The CM HAF 932 is 100.00 (I can't beleive how cheap that is.) My friend just got one. Excellent build quality and excellent design-wise!
http://www.coolermaster.com/product.php?product_id=5363
PLus, the 800D is Fugly!
I like my 1/4" thick all aluminum CM Stacker 832 better than all of them:
http://www.coolermaster-usa.com/product.php?product_id=2704
How vulgar
I'd rather cut out my own rectum and eat it than use that case... LMFAORZ!!"£!"£
I like simple cases, no windows, minimalist.
Ok, first the 800D is not ugly. Its goregous in its under stated minimalistic nature. Second you can always get a slide out shelf for your rack. I personally do not like these, however they are a necessary evil sometimes. You can then just lay your tower down on the shelf and you are good to go.
http://www.server-rack-online.com/rack-mount-shelf.html
The shelf will take up an additional U of space, then just lay the tower on it.
Oh, and I know it is probably not something you want to do. However I would really like to see the hacksaw heatsink.![]()
Like I said, just fill the pipes about 1/4 full with gasoline, then seal them with JB weld.
Get a really long extension cord, like 100 feet.
Let Line pack rip!
This will be the coolest video on Youtube:
"Overclocked 920 blows up!"
