I†'s Alive *w/pics*
what a nice system man, im jealous. Compared to you im still in the dark ages with my computer set up.
§·H·ï·Z·N·ï·L·T·ï where do you live :D, really nice setup you got there, you should be proud.
he lives in scottsdale, arizona.
sup garritt?
sup garritt?
Hey Dave! Nice to see that your a Gawd on here, you really know your shit.
LOL, we had some good times Overclocking over at Brad's house huh? Remember when we took the drill to my CPU heatsink on the old HP P4 SFF, hahah one lil slip and it woulda been in the junk pile :eek:
I was looking at some of your other posts and O M G the stacker is looking sexy man!
I still need to stop by and see your new house bro, maybee we can play some 360 or something :D
Do you still talk to plaps?
BioPort said:
some aquaporn
cuplex xt
twinplex pro gpu
twinplex pro chipset
aquastream
aquatube
black ice pro x-flow 120.3
a bed may not have static, it depends on a lot of variables. humidity, what you are wearing, what the material is made of etc.
to comment of the other posts, you better believe static can fry your hardware. ESD is not a myth, and even if it does not kill it , the damage can be cumulative. Some folks don't even use PCB after they have installed more than just a few times. When you hear of a fried board more than likely that was the culprit somewhere along the way. I always ground myself to faucets, pipes near work bench area, furnace, any large metal object nearby.
to the original post, that is an awesome rig you built there, wish I could see it in person. Good job dude.
Here is a updated pic that shows tv better connected to 360 and new layout for the setup...
Having the Senn 595's amped by the Harmopn Kardon is amazing...
I changed the way the AC unit exhausts the hot air. The hose in the old setup was creating alot of heat so I made the hose only 1 foot and then insulated it and made a hole so that I could keep the blinds down of the window, it dropped room temps another 4 deg, so I'm around 69.8 to 72.5 avg. for room temps...
cool system
are those case fans loud? I mean, would you have to turn up your tv any if your tv is already at a low volume?
Mace said:
cool system
THe 120mm fans are not loud at all, but the CPU is 80cfm at 40db and its loud, but i only ruin it that high if I oc my 3700 to 2.9 normally its 2.8 so i don't need full rpm.
Here is a small clip of my room in action. It's not the clearest video because the camera is like 6 years old and I'm using a $40 USB box to feed the video to my PC.
When I get a chance I want to make a better one, but for know this is good enough.
Video of Setup...
Damn. Thats all I have to say. That was tight, the door shaking and the sub bouncing. crazy..just crazy man.
