Is this psu capable? Having a hard time find a decent psu that frys has in stock that isnt overkill.
http://www.frys.com/product/6159219?site=sr:SEARCH:MAIN_RSLT_PG
I figured that coolermaster might be the better buy. Its a new power supply with the same exact specs as that corsair. Looking at reviews that corsair is 2 years old while the cooler master is a very recent model. They are also the same price.
Of course GX 750 W offers as advantages having four power cables for video cards and more SATA power connectors, but it is only safe to run this new Cooler Master unit up to 450 W.
My toughpower has 4 18 amp 12 volt rails. The box says the minimum requirements is a 600 watt with 40 amp 12 volt rail. So does that toughpower technically not meet the power requirements? Altogether those 18 amps add up to well over 40. Or is it imperative that its a single 12 volt rail with required amps?
So I guess my question is does the 4 18 amp 12 volt rails add up to 72 amps? Or is it literally 4 18 amp rails where power isnt added? Maybe one of the rails blew and thats why it's only have ass working now?
I also thought the hx was the higher quality model. The tx is touted as the energy saver type model...
I agree, sounds like PSU. That is why I recommend expending a good chunk of money on the PSU....you can upgrade many parts but the PSU normally stays with you so it makes sense to get a really good unit that you can keep for a long time.
Sorry to read this, the 480 is an awesome card...hope you get to enjoy it soon.
From what I understand my psu was not a piece of junk. Now that its broken it obviously is but ive made sure to not get garbage psu's. It is three years old. I expected maybe during gameplay I would get freezes due to power supply not being up to snuff. I didn't expect my psu to get killed on initial boot up.
I think the problem may be daisy chaining the adapters as you don't know how the four +12v rails are split up. One of the rails may have been overloaded since you had to use a bunch of adapters.
Ok I figured it out. The 8 pin is detatchable making it a 4 pin. The bad news is im getting the same thing. Both the 24 pin and the 8 pin are hooked up, try to power on with new psu and NOTHING. No lights, no attempt to spin up, just dead.
I havent taken the motherboard out of the case. The only thing I have done is take the psu completely out. I had it posting before when i didnt have that hard drive plugged in and it was posting. Put the psu back in and tightened everything up and its been completely unresponsive ever since.I need to ask, since you have taken the machine apart several times now. Is the chassis connector that you power on the machine connected to the MB now?
And yes I made sure the power switch is connected correctly to the motherboard
Fermi is in its box right now. I tried firing it up with just the cpu with no videocard and 1 stick of memory. Im assuming it can fire up like this. Yesterday it did.Check the power path (Socket, PSU (with on switch)), connectors etc. Make sure you have minimal connnected upon first test (MB with CPU, 1 mem chip, GPU, keyboard). Reset bios. Don't use the GTX480, but rather the 8800 which you know works.
You think my cpu and memory are unharmed? Would hate to order a new mobo and find out I need to replace those too. Boy I thought I was getting a nice upgrade but im going back to square 1... Oh well, worse shit can happen but this sucks.I'm sorry to hear that. I used to have a TX750 and it's a good PSU. I'm afraid that the GTX 480 and the Toughpower may have damaged your motherboards (both of them). I seem to recall reading some bad things about the Toughpower somewhere but I can't remember what it was exactly.
Just got done plugging this new psu into my core 2 duo system. Same thing happens with the tough power. Except now the cpu fan wont spin even with a flick. The psu fan turns on though.
It did until I put everything back together and tried to turn it on. Since then when I try to power it up nothing happens at all. So if i get a new mobo and the same thing happens the cpu is fried as well? Anyway i can test to see if the motherboard is getting power but the cpu isnt working?Did it fire up before in any combination with the previous PSU? If not you may have fried you're board or cpu.
I bought my cpu/mobod the fermi and this new corsair power supply from frys. Im going to go back there wit the fermi and explain to them the situation. I was concerned when I bought it about the power supply and told their guys that. They thought I was good to go(I should have known they didnt know anything). Basically this fermi card left a trail of bodies with most of my equipment bought from them. I know they have a tech center there so im hoping they can hook me up and test out all my parts individually and maybe give me some sort of discount because I have purchased a lot of stuff from them. If they say no, well it was worth a try.Without a working cpu no you won't be able to power up the mobo. Its possible if you get another mobo that it would power up but only if the cpu was not fried as well.
You're in a tough spot now , you have to figure out which is the problem. If you aren't close to the store where you buy parts you may want to consider buying both the mobo and cpu then returning whatever isn't required.
Edit: After further research I dont like what I read about the coolermaster "Cooler Master GX 750 W looks like a good option for users looking for a mainstream 750 W power supply, however it has a major flaw that prevents us from recommending it: noise level at +3.3 V and +5VSB outputs were above the maximum allowed when we pulled 600 W and above from this unit. High noise levels overload and can even damage components on your computer." http://www.hardwaresecrets.com/article/917/10
Corsair tx 750 or 850 it is.
I'm sorry, who gives you this information? Coolermaster makes crappy PSUs and in retrospect it's no surprise that your system went down in flames when you attempted to plug a power hungry GTX 480 into it.
The OP was using a Thermaltake Toughpower 650W PSU when the system died. He was thinking of getting the Coolermaster as a replacement until he found out that the PSU was a piece of shit.
So no, the OP has not bought or used the Coolermaster PSU.
