For a DIY window that has the factory look, the most difficult part would be the clean cut of the aluminum. Most of the big manufacturers have laser/plasma/water cutters or simple molds involved in the automated process to make such cuts. Attaching it to the inside of the case is the easy part.
You can cut the window cleanly yourself if you have MAD dremel skills or a jigsaw, which would be the most inexpensive avenue. Or have a machine shop laser/water/plasma cut the aluminum hole to the size you want and simply attach a window yourself. And you can get a piece of perspex or acrylic sheet from your local Home depot and cut it to size yourself for cheap. That's how most shops do it anyway.
In the case of the PC-7, its just the reverse of a bolt on window. You simply attach the window to the aluminum from the inside with screws and cap the screw when it comes through to the other side with screw caps.
I like my Lian-Li, don't get me wrong, but this is the first case I've ever cut my finger on. Oh, the irony!![]()
It's all your fault I bought one... Every MF'er who posted a picture of one
xoxide was out of black, so i got silver instead, now I wait...
I've been toying with the idea of grabbing a slot blower. How loud is the antec one? My rig is by no means silent, but it's pretty damned quiet so I'd rather deal with a few degrees higher temps on my GTS than a screaming fan. I don't OC my video card either way so that doesn't factor in at all.Love the case, just coming back to ATX (had an SG01).
It gets smokin hot upstairs. I installed an Antec slot blower and improved things a lot, see pic. I was thinking about water cooling, but the northbridge gets really hot too, so I would need some active cooling here.
*snip*
Kinda off topic here. I wonder if the high temperature on northbridge caused by reversing the heatpipe direction...![]()
yeah so I ordered the case and luckily it shipped from NJ which means 1 day for me in DC!!! But I am waiting on my p5b deluxe to get in. Now i need to find 2 more gray jerkers shelves to hold this and my new 360 i just got in...![]()
and CPU units
good luck on that, jerkers are discontinuedmy ikea in Houston only had a few of the add on shelves and CPU units hidden down in the flat box area. I was looking for the shelf on the show room, wasn't there, but I had a hunch and checked the desk area downstairs in IKEA, there it was
got my hx620psu installed.... the fan is on the bottom of it facing down... which is pretty much blowing into the case floor?
what should i do about that?
if it put it the other way... 1 its updside downhaha and 2 the HD cage is right above it
what would be the best option for this?
uhh... your PSU fan doesn't blow out of the bottom. it sucks in and blows out the rear where the plug is
oh thats right... wow forgot about that
lookin good bud.
yea - modular PSU's ftw.
you goin air or water?
mATX? plans for a big radiator on top or something?
cuz it can be done w/ a full atx board...
V
I was wondering if you guys who are water cooling your A05's could tell me how much your rig weighs?
Also if your specs aren't listed in your sig let me know how many hard drives and DVD/CD drives are in your rig, thanks a lot.
I want to build a reasonably weighted rig I can bring to lan's to replace my currently heavy ass water cooled soprano (38 pounds)
Thanks!
just got my case in today myself.. but my rig in there and I totally love it.. i will post some pics later this week.. my wiring job is ok.. cant say its the worlds greatest but it will do.
ok so i have a scythe ninja now in the machine, I was wondering should I have the fan on the side to pull the hot air or on the other side to blow over the heatsink???
the only problem with that is the space between the heatsink and the back case fan blowing in. remember this case has the opposite cooling affect. Unless... how would it be if i turned around all my fans back the other way??
