Great for hiding cables under too... Space under the PSU, space behind the bays, space behind the Mobo... Awesomeness.
I was thoroughly impressed with how much room this case had... Honestly, if you only need the bare minimum... 2-3 harddrives, 2 DVD drives... Best case I've had to work with...
Unfortunately I need a minimum of 6 HDD spots right nowUsing an Antec 900 with 2 3in3 bay modules and 2 DVD drives... might look at the Antec 1200 when it comes out or a bigger Lian-Li...
I wouldn't recommend running any thick cables, like the motherboard power cable, under the PSU if you have a PSU that has an underside intake fan.
I have a thermaltake toughpower psu, and the only cable I was running under it was the 24pin mobo power cable. I started to smell something burning. Took off the front cover, touched the psu, and it was HOT!!! Ran the cable another way, and it is fine now.
You do realize you can flip the PSU over... so the intake fan is facing up..![]()
Can someone explain to me how the fan clips latch on for the Thermaltake Ultra 120?
Although, I demolished the ones that came with by twisting and turning them around so much already. But, there's still hope with so many of you guys having the same fans and heatsink.
Oh, I tried to latch onto Yate Loon 120's and no go with stock fan clips (despite twisting the heck out of them!!)
Just finished my roof mod. I can tell you, the VC cooler is much happier with a fresh, cool supply of air now. Temps have gone down all-around.
[/IMG]![]()
the roof vent, ordered from Frozen CPU. Its an a/c Ryan grille. I'm using the Silverstone 120mm that came with an old NT08 I had lying around. I have it on its controller, barely audible.
[/IMG]![]()
I am not seeing this on their website... I would love to get one of these!
Also on a side note, does anyone have a picture of this tower beside a normal Lian li mid tower... I just want to see what it looks like compared to another tower as far as size goes..
Thanks
-Nigel
I think it will go over the edge of the motherboard, and whether or not it hits anything depends on the motherboard. It appears that it extends out to just before the ram slots. What motherboard do you have?I am new to the forum and saw everyone's pc-a05b rigs and I am amazed! I was wondering if someone would please go out of there way and see if a power supply with an 8" length will fit in the case w/ a full ATX motherboard with impeding with any of the board components. There is a 7" power supply image but I own a thermaltake 1000w power supply that is 7.87" long, I am afraid it will not fit.
I was also wondering where to get the side panel cut at? Can I go to Home Depot or something? I know they sell kits with the windows and stuff, but no one really discloses where to simply get the original side panel cut.
Thank you for the help, i await responses soon!
Can someone link me to a website with cheap side panel kits and cable management kits?
Cut square hole, put on front.Guys I am still trying to figure out how to improve the exhaust on the front of the case without completely ruining the clean look. Small cleanly drilled holes in a vertical rectangle pattern is the only thing I can think of that would look halfway decent. plan to overclock my new system as far as it will go and I do not want to have to snap off the front cover ever time I am going to play a game or something.
Please give me some ideas!
Hey fellas here is my self made exhaust!
If I was doing something like that, I'd want it done on a CNC machine.well you could just figure out how far you want em spaced and then line em up on the computer, print, tape and drilll... it would look like older LiLi fronts w/ the holes for exhaust/intake
Didn't try burning anything yet, but it works with DVD-ROM disks.
"Red Theater" theater is the paint color.on a side note, what color red did you paint the theater room and who makes it? i can't remember off the top of my head lol
Sherwin Williams makes it, and it is the "duration" paint. It runs around $57/gal or something ridiculous like that. And it took 4 coats to actually make it looks right. It is a bitch to paint with.
