It's alright. You must really love your jobIceWind said:I got the impression you were taking a stab at me, then I noticed the. Ung...I hate work, I get too stressed out
Syndicated_Death said:yes they do.. the phospher burns out.. I have a dead pixel on this viewsonic here and a friend of mine also has a viewsonic with the same prob, but my viewsonic at home is perfect
peacetilence said:Does the glass panel on SED's bother anyone else? I should also ask do SED displays exhibit the same 60hz flicker than regualr CRT's display?
There is no noticably flicker with SED displays, because the display isn't being scanned by a single set of electron emitters. Each pixel is driven directly, so even the concept of a refreshrate, much like with LCDs, doesn't apply anymore.peacetilence said:Does the glass panel on SED's bother anyone else? I should also ask do SED displays exhibit the same 60hz flicker than regualr CRT's display?
That's like saying that modern LCD screens are basically just blown up digital watch displays.logo29a said:Does this include SED's? They're basically nothing more than a matrix of tiny CRT's.![]()
Araanor said:That's like saying that modern LCD screens are basically just blown up digital watch displays.
Araanor said:Modern as well as ancient LCD displays use liquid crystals to block out light, same principle.
Hyperbole versus hyperbole.
...?Mojo said:Does anyone know when the next generation monitors will be going mainstream (ie: Available on Newegg)?
SED displays should become available for those with less impressive budgets in 2007-2008. OLED displays might become available for the same people in 2009-2010, although this might be sooner.Mojo said:...?
The reason they only talk about 50+" displays is because the profit margins on such big displays are the highest, as I mentioned previously in this thread.TSS Modder said:anybody think that theyll actually make these displays in sizes smaller than 30"? as i an actual computer display?
all they ever talk about is about how theyre gonna use them to make screens bigger than whats currently possible (ie +60"). i never hear anything about computer displays. there would be such a freakin big market for that...
Seems you don't know too much about LCD technology..logo29a said:An SED will have faster response times, better viewing angles, better color rendition, better contrast, and better blacks than LCD technology ever will. Once SED's start coming out there will be little reason to buy LCD's, period. There is so much money invested in LCD technology that I'm afraid it may delay SED technology. On the other hand, whoever gets there new tech out first will have a pretty advantageous head start.
Presumably SED and OLED displays will be cheaper to produce than LCD displays, so even if all those displays can match each other in features, then the price may just be the decisive factor in favour of the former two.Stereodude said:So, SEDs aren't going to much if any performance advantage over LCDs. Whichever is cheaper to buy is going to dominate the market.
And LCD haters annoy me.Elledan said:...
CRT haters annoy me.
Elledan said:Do CRTs have dead pixels?![]()
Me too1c3d0g said:And LCD haters annoy me.![]()
Price will definitely be the deciding factor, but I wouldn't hold my breath for cheap SED and OLED sets. OLEDs are not cheaper than LCDs in small sizes now. Where SED falls is hard to predict.Elledan said:Presumably SED and OLED displays will be cheaper to produce than LCD displays, so even if all those displays can match each other in features, then the price may just be the decisive factor in favour of the former two.
Stereodude said:Seems you don't know too much about LCD technology..
SEDs do have a better response time than LCDs, but the actual LCDs response times are not the issue anymore with LCD displays. The issue is that a LCD is not an impulse display, but rather a sample and hold display. Black frame interleaving, scanning backlights, and frame rate interpolation to 120Hz take care a lot of these issues.
Stereodude said:SEDs will not have any better color than CRTs. LCDs with LED backlights have no problem smoking CRTs in color reproduction. The latest VAN LCD panels do not have contrast problems. You eye can see about 100:1 at any instant. The best LCD panels can do 1200:1 ANSI (checkerboard). That's more than adequate for CR. In terms of black level, backlight modulation can push the dynamic range of a LCD to >10,000:1
Stereodude said:You eye can see about 100:1 at any instant. The best LCD panels can do 1200:1 ANSI (checkerboard). That's more than adequate for CR. In terms of black level, backlight modulation can push the dynamic range of a LCD to >10,000:1
You can't have a 1,000,000,000:1 CR and have a bad black. It's a ratio. The white aren't getting any brighter with new models and yet the CR is improving, so that would have to mean that black is getting darker.The_Incubator said:The problem is, quoting dynamic range and contrast ratio figures to show LCDs have decent black-level performance is a red herring.
The black sucks; I don't care what the overall dynamic range is if the baseline black looks like some fuzzy 10% gray, no amount of dynamic range is going to make up for that. I don't care if it's 1,000,000,000:1, an unblack black just ruins everything.
Nick
Hitachi has a 32" LCD with black frame interleaving.logo29a said:Do we have any working displays out there with technology? A liquid crystal will always require a certain amount of time to reconfigure and it will always be slower than a CRT.
I'm not overhyping anything. You can buy LED BL LCDs now. Sony sells a 46" one called the Qualia 005. NEC is selling a 20.3" LED BL LCD monitor. Nearly everyday at work I work on LED BLs for LCDs. We measure the R, G, and B of the panels with CCFL BLs and white LED BL, and RGB LED BL. The RGB LED BLs cover the largest portion of the NTSC Ratio (and in some cases cover more than the 1953 NTSC primaries). Funny thing is the 1953 NTSC Primaries were discarded because they were deemed unattainable. Now pretty much every RGB BL LCD panel is over 100% NTSC ratio.We'll wait and see. Besides, I was refering to current LCD technology as this was what the orignal poster was refering to. If a better LCD technology comes along, I am all for it. However, I believe that you are overhyping LED LCD's and that that technology is a long ways away. Do you have any sources that back up your claim that they will have better color rendition?
it's commonly accepted that somewhere between 100:1 and 200:1 is the limit. Regardless, the difference between 100:1 and 300:1 is pretty small when you're working on a log scale (which your eye does).Your assertion that the human eye can only percieve 100:1 contrast is rediculous. The maximum limit is about 300:1. However, even small amounts of ambient light reduce the percieved contrast ratio of a display dramatically. For true blacks I wouldn't take anything lower than 2000:1. Backlight modulation is a solution for LCD's, but it certainly isn't a very elegant one. Nor will it be a cheap one.
if i had 3000$ to spend on a display, id be happymjz_5 said:now, if i can purchase an 85 inch display for less than 3000 dollars, i'll be happy![]()
Projector and screen?mjz_5 said:now, if i can purchase an 85 inch display for less than 3000 dollars, i'll be happy![]()
Stereodude said:it's commonly accepted that somewhere between 100:1 and 200:1 is the limit. Regardless, the difference between 100:1 and 300:1 is pretty small when you're working on a log scale (which your eye does).
Stereodude said:Nearly everyday at work I work on LED BLs for LCDs.
Actually I work for a military contractor to put ruggedized displays in vehicles and other applications. We don't have a bias towards LCDs. If there were a better solution we'd be using it.logo29a said:Well there we have it. You're in the industry. Now we know why you're pushing LCD technology so hard.![]()
That's not really why a display needs a dynamic range that exceeds a 300:1. It needs a dynamic range that far exceeds 300:1 because our eyes adapt and can still see 300:1 when the display is only using 30:1 of it's 300:1 (ie: in a dark scene).logo29a said:A display will need to display much higher contrast ratios than this due to even small amounts of ambient light affecting blacks much more than whites.
Stereodude said:Projector and screen?
Stereodude said:That's not really why a display needs a dynamic range that exceeds a 300:1. It needs a dynamic range that far exceeds 300:1 because our eyes adapt and can still see 300:1 when the display is only using 30:1 of it's 300:1 (ie: in a dark scene).
They trick is to make the display always use it's 300:1 even in the dark scenes. This is done by backlight modulation and some fancy processing.
