I'm finally in the market to build an HTPC. However, all it needs to do is playback files from a file server. I plan on using XBMC as a front end, all i really need help on is hardware advice.
FYI,
This will be connecting to an Onkyo TX-SR606 via HDMI. (or best possible connection available) Which in turn connects to a 42" Philips 1080p LCD TV.
I currently have the following as my main workstation that I've been debating on moving to HTPC duties. (subsequently moving the i7 rig back to workstation duties)
Zotac GF9300-D-E Wifi miniITX
Intel Pentium E5200
XFX GTS250 1GB (GS250XZDFC)
4GB Patriot Extreme DDR2-800
1TB Samsung F1
Silverston Sugo SG05
Now, its a decent little system, but it seems like this would be overkill for playing back files. (1080p/720p)
Should I use the above? If not, how much "power" would I really need to just playback HD files? Some research leaves with with little power. I'm really concerned about the video card and in another thread I saw this suggested.
Other options would include a used AppleTV or MacMini running XBMC. Providing they have enough power to playback HD files. I wouldn't hesitate building a new pc, but it needs to be as small as the current Sugo SG05 and cost ~$350.
Any advice or build suggestions is greatly appreciated.
FYI,
Intel Pentium E5200
1TB Samsung F1
