HTPC build help
hipsterdoofus
Hey all first post here. I used to run a proprietary RCA dvr that died on me a week or two ago and was wanting to build an HTPC to replace it for the dvr capabilities. Also it woudl be our dvd player as well. I don't intend on getting a blueray drive for it now, but do plan on it in the future.
I'm a member at another site trying to get some info but theres only like one guy who makes suggestions, so I thought I would try you all out.
Heres my situation: I already ordered an HDhomerun networked Tuner - it is on the way. I also ordered a 1TB Sata drive.
I am thinking about going with MicroATX and put the unit under my tv in the cabinet. I currently have an older tv, which I will eventually upgrade to an HDTV, but for now, I will need a way to get video over from the HTPC to svideo or composite/component. Anyway, would love any suggestions.
What are you looking for suggesitons regarding? Most new video cards can output via component, as well as HDMI/DVI, and VGA.
Well, I'm very unfamiliar building anything in a form factor other than ATX, so i guess some suggestions on boards to use, cases, CPU. What I hope to do is run the windows 7 beta temporarily, then perhaps buy Vista later on when I can get a free upgrade to windows 7. Obviously I'll need enough to record and playback hd and such. I just am really clueless about this usage fora computer, so any help I can get is appreciated.
3) Where do you live?
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Addendum:
- What TV do you have?
- When are you planning on getting that HD TV?
Ahh..thanks for the questions, I'm glad to get more interest here than I had at the other place I posted! Ok, here are my answers:
-I saw some pricing another forum of like 4-500 for the base system. I don't intend on using it for gaming or anything, just dvr/playback (eventually blueray playback). I don't want to scrimp though, so I believe I allocated $700 for it and I already have a drive on the way as well as the hdhomerun network tuner.
-Oklahoma
-CPU, Ram, Case, any additional components needed to hook up to an older tv that has an svideo/component/composite hookups, OS (probably, although I was considering running windows 7 beta for free), also remote and such, although I could get that stuff separately down the road.
-No - all new parts, only thing bought though, as mentioned above is a hard drive and a tuner.
-I Have the money budgeted for this month. My old dvr died so I would like to do it fairly soon. Since I got the hdhomerun, I can easily record to my existing computer for the time being, but would rather do this within the next month.
-Nothing real fancy needed. Again, as mentioned, just need the ability to play on an older tv at the moment.
-Oh dear, you would ask that. I'm not sure the exact model - its a JVC model from about 2002/2003 or so
-I'm going to say it would probably be at least a year if not more - unless my current tv dies. Especially since I'm putting for the money on this htpc right now.
Hmm that S-Video requirement is a bit troublesome. Oh well. here's what I recommend:
AMD Athlon X2 4850E CPU - $56
Asus M3N78-EM Nvidia GeForce 8300 HDMI mATX Motherboard - $90
Kingston KVR800D2N6/2G 2 x 1GB DDR2 800 RAM - $20
Samsung SH-222F 22X DVD±R SATA DVD Burner - $26
XFX HD-435X-YAH2 Radeon HD 4350 512MB PCI-E Video Card - $50
Antec NSK2480 mATX case with Antec Earthwatts 380W PSU - $97
Total: $339 plus tax and shipping
Try out the Win 7 Beta for now. If it doesn't work well for you, then get a copy of Window Vista Home Premium 32bit for around $100. When you get the HD TV, you can use the HDMI port on that mobo for the HD TV.
Alright - cool cool...Honestly never run an AMD setup before (not really against it, just never have).
couple of questions I guess -
-I'm not real familiar with the Micro Atx form factor - will a full height card like that video card fit in there?
-As far as memory requirements and such - I guess that the onboard video will work fine and have enough oomph after I quit using that radeon card? I am very unfamiliar with the requirements for hd playback and such. The tuner I am getting is a dual tuner so I obviously want to be able to record one and watch one or record two at a time. (Again, not questioning your judgement, I just am looking to be educated :) ).
In your opinion, is Micro ATX the best way to go? It seems to me to be the best compromise between ATX and mini ITX - just wondering if you agree?
-Everyone seems to recommend 2 gigs of Ram - I realize there are limitations but I believe a 32 bit system will see up to 3 gig - is it worth a few extra bucks to add that, or no real performance boost? Remember I've budgeted quite a bit more for this - I'm not looking to spend it necessarily, but I figure I may as well make sure i have a decent set up that will last me a bit. I'm holding off on the bluray since I don't have an HD tv at the moment and I figure the drives will come down a lot soon.
-Also I take it i'll want to add on a remote - mouse? keyboard? I'd love your recommendations on those as well.
I was planning on doing exactly what you said on the Windows 7 - getting the vista home premium if need be
- Yes a full height video card will fit in that case
- Yes the onboard video is more than enough to watch HD content. In fact if your TV didn't need a S-Video connection, I wouldn't have included the video card.
- Yes, mATX is the best way to go for HTPCs. It is the best compromise between ATX and mITX.
- The extra RAM isn't necessary for a HTPC.
- Don't have any recommendations for a remote, mouse, and keyboard. Will have to get back to you on that.
Ok...thanks. I'm still in decision making mode - but I very much appreciate you writing back.
I have a friend that sent me some recommendations last week that were somewhat similar. He forgot the case though in his listing :D. He's very against using the PS that comes with cases...bad experiences in the past I guess - but I don't see many that come without a ps. I've seen a lot of recommendations on the antecs, so I guess they are pretty good.
Yeah, generally the PSUs that comes with cases are pretty shitty/crappy. So I understand why your friend would be against using the included PSU with that case. However, Antec actually bundles good PSUs with their cases nowadays. The EA380 is a very good quality PSU and should not give you any problems at all with the above setup.
My suggestion:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129034
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
http://www.newegg.com/Product/Product.aspx?Item=N82E16813153119
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102724
http://www.newegg.com/Product/Product.aspx?Item=N82E16820161042
With shipping and all that it's probably around $350 or so. That video card supports component output which is what you should be using instead of svideo since component is a higher quality connection but when you upgrade to a blu ray drive you will also need to upgrade the video card since this one isn't going to be all that great for it. Originally I would have suggested a motherboard based on NV's 8000 series or 9000 series IGP since you mentioned blu ray playback. I don't know of any that still carry analog connections like svideo/component though so we have to go with that video card.
It all depends. I don't like using my HTPC like a PC, I don't ever want too or need to drop to the desktop unless I'm monkeying around with something and testing it. I want this thing to act as much like a consumer electronic device like as possible; it should act like a Tivo/DVD player/whatever which to me means that all of my media is accessible by remote and a remote is the best input option.
Thats basically the way I feel as well - This isn't necessarily my surfing computer (wouldn't look good on my old tv anyway).
My suggestion:
Pardon me if I'm mistaken - but this seems to be a little bit lower end compared to what Danny Bui suggested?
Well the mobo is lower-end (IMO, well more of fan of the Gigabyte G31 mobo) but his build would also get the job done as well. In fact, the CPU he chose is FAR faster than the one I chose.
Another alternative would be to go with my build but with CrimandEvil's recommended card. IMO that would be a good choice since the card will provide component output. When you finally get a HDTV, you can just ditch the card and go with the onboard video/HDMI support of that mobo I picked up.
As Danny mentioned the board is rather low end and mostly aimed at "being cheap without being crap" since the mobo doesn't really matter all that much in the great scheme of things if you're not using the onboard video which the OP can't use until he buys a new TV which should be done ASAP.
I actually waited to build an HTPC until I had a suitable TV for it. An SDTV sucks for this kind of thing.
But the card that he recommended - appears to be an S-video out with just an adapter to component - wouldn't that still just end up giving you S-video quality?
Well as my DVR went out kind of unexpectedly, it kind of puts a dent in my ability to buy both. I suppose one alternative would be to just wait and record to my desktop for now (slap the TB hard drive in there for space) and save up money for an HDTV. Theres a slight chance that could buy it and the HTPC with tax money...but what would suck would be to watch crap on the PC screen until then. As I understand it, it will work on SDTV, and movies and such will look about the same as they have, just that the screen will not look as good due to the low resolution - is that correct?
Not really. If you look carefully, that's not a normal 4Pin S-Video out port. Note the extra three pins. Those extra three pins provide additional support for component video.
The Svideo out looks the same on the card he recommended as on the one that you recommended - so I'm not sure that I understand the difference between the two cards (other than the fact that his came with an adapter to component). It looks to me like the one you recommended has the same ability with the three extra pins. On the other hand, I realize his is cheaper - but would it matter at this point the difference that yours is 512 and his is 256?
Not at all. You might be able to find a 7 pin component cable and go with the Danny's better video card (the 4350 would be able to handle Blu ray just fine but a 4550 is the most you need for playback). If you can find a 7 pin component/svideo cable.
Ok so heres a silly question - I'm buying a mother board that has HDMI outputs - I'm only buying a video card so i can (for now) get video to the tv. Is there a possibility of using some kind of DVI to component adapter to do the same thing and skip buying an extra video card that i'll only use temporarily?
nope
Haha - thanks for your succintness - but why? There appears to be such a thing out there.
Not a lot of video cards support component out functions through the DVI port. In fact, I can't recall of any current video card (onboard or dedicated) supporting that function nowadays.
Yes there are DVI to component cables (Scroll down to DVI to 3 RCA component cable):
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10235
BUT you have to read what they're for exactly (Same for all those DVI to component cables on that site):
This cable is primarily used for connecting video projectors with Component-in capability through it's DVI-I port. It can only function with a DVI port that is either able to recieve or transmit Component signals (Y, Pr, Pb).
IT WILL NOT ALLOW YOU TO CONNECT YOUR COMPONENT VIDEO SOURCES TO A REGULAR COMPUTER MONITOR OR HDTV unless you monitor specifically has this capability. Most do not. (Please check the documentation for your computer monitor)
THIS CABLE WILL NOT ALLOW YOU TO CONNECT YOUR COMPUTER'S DVI PORT TO THE COMPONENT INPUT ON YOUR HDTV unless your video card supports component out function through it's DVI port (please confirm with your video cards documentation before purchasing. Some require adapter, not this cable.)
This cable will not convert RGBHV into Y, Pr, Pb.
This cable will not convert Y, Pr, Pb to RGBHV
This cable will not support Y, Cr, Cb.
This cable will not convert digital signals to analog or visa versa.
And then there's the issue of of analog and digital signals which will require too much explanation (at least from me). So simply put, the answer is no.
Ok - well thanks for that - back to the note about the video card and using the one that Danny originally recommended - I thought I remember seeing this when digging through ye olde box of computer junk the other night - I actually have an s-video 7 pin to component cable - much like the one shown on that 3450 (except that the ends are all together in a plastic casing - so I guess I could buy the slightly better card and go that route....but then again, if this is just temporary - I may want to go with the slightly cheaper card since in the long run what I am banking on is my onboard graphics...
Ok so possibly one of my final questions - in regards to the Mobo /CPU, I realize its a pretty good deal - but since I have budgeted quit a bit more that this will cost - would I get more out of the machine if I did something slightly better? Not looking to throw money away - just wondering on if there is a slightly newer config for a little bit more money, or of this will be the best for me.
would I get more out of the machine if I did something slightly better? .
Not really. All of the above HTPC setups will perform just as well as a $1000 HTPC watching SD and HD content. So there's really no point in spending more than the above ~$350 setups for just watching HD and SD content.
Again, thanks for hanging with me as I learn this stuff - is there more resources used then by watching the HD stuff than by recording it? Would I have significantly more resource usage by recording 2 streams at once? The tuner I am getting is a dual - but once again, thats the primary purpose of this machine - so its not like i'm doing to be doing anything else on it.
If the TV tuner you're using is an actual hardware tuner, meaning that it has an onboard CPU to encode/record/decode, content, than resource usage while recording HD content (with one or two streams) would only be a little more resource intensive than watching HD content IIRC.
However, if the tuner you're using is not a true hardware tuner, meaning that it uses the PC's CPU to do the encoding/recording/decoding content, then yes you'll see significantly more resource usage when recording HD/SD content.
However the X2 4850e or E7200 should still be enough.
I am getting the hdhomerun which from what I can tell is a hardware tuner...so I think I should be ok.
Ha! Database corruption - theres a good way to get my post back on page one HAHAHA. Ok, seriously - I have all my parts on the way - should be here tomorrow. My question is - I'm using a 1TB hard drive - probably with Win7 Beta or Vista Home Premium on it - how would you all recommend I partition it?
Thanks
Thanks
If you are using it to record to using VMC then don't bother partitioning it since you can't select your record too location. If you are using a different PVR app then give Windows 25/30 gigs and leave the rest for recording space.
VMC? Are you talking about media center? Sorry, I'm not familiar with all the acronyms ...if thats the case, didn't know you couldn't set a record location, but thanks for the info.
VMC = Vista Media Center.
Yeah he's talking about Media Center.
You can't select where to record to? That seems odd? If I can't change it, then I guess one big partition and is there a recommendation on the block size or should I not worry about it.
Also a final question for now, I need to get a remote ASAP obviously - from what I'm reading, the basic media center IR remote is what I want if I want to control my TV as well - does this sound right?
I have Vista Media Center and you can select where to store the video at. In my case I have two hard drives and I can switch the recording from one to the other. I cannot specify what folder (to my knowledge) but since the second hard drive's sole purpose is to store video I dont care :D
Hmm and I will install Windows 7...so I will go ahead and partition and put the videos separate.
Got my parts today and did the build. Of course I'm tempted to fire it up and install, but I have work tomorrow and no idea how long Windows 7 will take to install. I was about to blow a gasket because the PS that came with this antec case only had one line with SATA power on it - and you couldn't connect both hard drive and dvd player at the same time (too far apart). I was about to get really mad and then I found the adapter to switch one of the molex plugs over. Still find it odd how many molex plugs they give and how few of the SATA ones.
In regards to video storage, when you go into Media Center (provided the GUI is similar to Vista Ultimate) you select Tasks>Settings>TV>Recorder>Recorder Storage and set the drive to what you want. Or at least it lets me do that with my ATI Wonder 650 PCI-E Tv Tuner.
Also normally the higher end PSU's come with more SATA, the onboard ones normally dont....and I do agree, dont like molex and its not really the standard anymore ;)
EDIT: You will want to check if you can change the storage location since your TV tuner is external. That might make all the diff in the world.
Thanks for the comments (by the way, like the username :D). So no one has answered yet, but I really need to determine a remote - is the standard microsoft media center remote a good one to go with for basic needs?
My tuner came with its own remote that I am using currently. It doesnt work great but it does what little I need it to do. The computer in my sig is attached to my HDTV currently, but will be moved into the bedroom pending the purchase of a 37" HDTV. I will be looking into this shortly myself as my next rig will be a HTPC build that will be attached to my 59" HDTV as well as my reciever (deciding between a Onkyo 606 and Yamaha Rx-V663). Any comments/suggestions on my rig are greatly appreciated as well. See thread here A quick search of the forum revealed lots of options but the basic MCE remote seems popular. Would recomend doing your own search and making sure it works for you.
An option I am considering is the Harmony One remote from Logitech. Seems you can get it to work with a computer if you have the right parts. Doing that would allow you to control your TV, HTPC, Reciever and other equpiment (think Xbox360) from the same remote.
I assume from your username comment you have read the books then? I debated between going for Ender or EndersShadow for quite some time...:). Went with EndersShadow as I like being the one thats just as smart but stays in the background...:D
