Thanks for the comments (by the way, like the username). So no one has answered yet, but I really need to determine a remote - is the standard microsoft media center remote a good one to go with for basic needs?
It's a good starting point. Honestly I'd recommend you take some of your HTPC budget and get a Logitech Harmony remote. The best ones are the 880/890 or One but there are more entry level ones as well. You still need to get an IR receiver like the one from the MCE remote, you can either just get the MCE remote with it and shelf it or look for a receiver on EBay.
As for the power supply, the Antec Earthpower has been around for about 3 years, before they had Sata powered dvd drives, and since they only have 2 HD mounting points, it makes sense for the power supply to only have 2 sata power connectors... at the time.
For a TV recording drive, make sure you use the biggest block size for the format... makes it easier to deal with all the large files.
