pls explain? is there any reviews out yet?
... based on bb23's initial impressions above.
Pete.
Pete.
ooohhh. ok....
Use this program: http://hardforum.com/showthread.php?t=1423433
When using clone mode, one monitor will tear. Wait for the tearing to roll off the screen, then take a picture. That will give you much more accurate results.
Pete.
Just checked for this in a Word Doc. Nothing that I see.[X]eltic;1035514866 said:The thing with the Dell U2410 was that some people complained that it was as if the screen was dirty on a white background.
The Word doc seems too bright to me at the default settings, though my eyes are very tired right now. So I lowered the brightness from 90 to 50 and it's very easy on the eyes. Nothing fuzzy about the text that I see under either circumstance.[X]eltic;1035514866 said:I've read complaints about a 'sparkling/twinkling effect' when reading text too, and even complaints about 'fuzzy' text. But since you don't really notice it bb23, I assume any anti-glare coating issues must be minor or nonexistent.
But not the LP2475w?The U2410 and the ZR24W both have an LG panel according to TFTcentral's panel database.
I don't know where IPS panels got the reputation for being slow because they're not. Most IPS monitors don't have any significant lag except for the ones with advanced color features or dual-link scalers.bb23 said:The main negative aspect I have been wanting to understand more has been the general lag IPS monitors have been said to suffer - and though this is a very secondary concern to me, I know it may matter a lot to hardcore gamers.
No, that's fine. The pictures show they are basically the same in terms of lag.bb23 said:Unless I did this wrong and/or do not understand the test, it looks like the ZR24W is very similar to the Samsung 204B in terms of lag.
I set my camera to auto and it set the shutter speed to 1/60 as we would expect. Fraps confirms the rate too. Is there something more I should have done?
That means the HP with scaling has the same amount of lag as the Samsung 204B at the native resolution. Scaling doesn't usually add lag, but it can on some monitors. Now the question is how much lag does the 204B have?bb23 said:Does it matter that the HP could not be set to its native resolution of 1920x1200 because of the Samsung's limit of 1600x1200?
I didn't see tearing in any of the pictures, so the video card must have sent both monitors the same signal at the same time, like a splitter would. The program can only synchronize with one monitor, so if the monitors weren't perfectly synchronized, the other monitor would show tearing.bb23 said:P.S. Not sure what you meant by "tearing", ToastyX. I did not see anything different to begin with than I did throughout the test. Maybe because the monitors are so similar in this regard?
Pete posted this link yesterday about the Samsung 204B:That means the HP with scaling has the same amount of lag as the Samsung 204B at the native resolution. Scaling doesn't usually add lag, but it can on some monitors. Now the question is how much lag does the 204B have?
Not sure if this helps to explain it, but the HP is on the displayport and the Samsungs are on the DVI ports. The card is an HD5850.I didn't see tearing in any of the pictures, so the video card must have sent both monitors the same signal at the same time, like a splitter would. The program can only synchronize with one monitor, so if the monitors weren't perfectly synchronized, the other monitor would show tearing.
Samsung 204B's input lag according to Digitalversus:Now the question is how much lag does the 204B have?
I don't think this sort of monitor is really aimed at someone with your kind of needs, I'd point you in the direction of monitors with true professional features like NEC's (I'd say EIZO too but the price premium is hard to justify over NEC).i should note that it is my job to create high quality images for editorial so my standards are quite high.)
Since you belong to the narrow band of pro users who find wide colour gamut's useful it's impossible not to recommend the 2690 WUXi for serious work, there is no comparison between a display that has a LUT that is programmable at a hardware level inside the monitor + colour / backlight uniformity correction features (ColorComp) and one that does not.
[X]eltic;1035516154 said:chris_n, have you seen any tinting issues with the HP screen? That was the thing that really stopped me from buying the Dell U2410, the pink/green tints.
Something else that's important to me, and perhaps I'm being very picky now, is that the monitor should be totally silent. I've heard of monitors that emit a high pitched sound.
so, the one question i have not seen answered so far.
hows gaming/movie viewing on this? i assume no noticable ghosting, or any other strange issues.
How deep is this monitor without the stand (ie. from the front of the screen to the back of the case). I am interested in hanging it on my wall, but the spec sheet says 9 inches without which has got to be wrong... If you could pull out a ruler it would be much appreciated.
Z
Question for chris_n,
Sorry if this question had been asked. Do you find it distracting if you have the ZR24z next to the U2410? I use to have a LG and a Samsung set up but the differences in the color hue, brightness and contrast just kill my eyes regardless of how I try to match them. That is how iI have my two 2410s now.
bb23 reports some greenish hue on his ZR24w, and I think you comment on how bright the screen is. Judging by only these two factors, do you think that the HP and the Dell will be a good match? Thanks
Really? Isn't using analog inputs tampering with the results? A monitor may use different circuitry and different processing routines for analog signal, whereas most of us will be interested in performance with a digital signal.
No, I never said that. Maybe you see that in one of the pics I posted? I don't see that and if you do, let me know what pic. Both Chris and I have mentioned the brightness. I am keeping mine at default (90%) brightness for the sake of the OOTB pics, but bump it down to 50% or less, otherwise....bb23 reports some greenish hue on his ZR24w...
CutterX noted yesterday that the HP ZR24w, the HP LP2475w, and the Dell U2410 are all made by LG, so they may be inherently more compatible?Question for chris_n,
regarding the 'dirty' look of the screen due to the AG coating. In my observation, this screen does exhibit somewhat a 'grainy' look when a blank white window is open HOWEVER it is not an annoyance to me. it is also certainly less than the u2410.
Good to know. So presumably if they are all IPS panels, they probably are more matchable Eyefinity-wise than my IPS and non-IPS panels.Most if not all IPS panels are made by LG who licenses the technology from Hitachi.
If this monitor does great in games I think I am going to buy it for sure.
