thanakornl
- Dec 10, 2008
PC_user, which mean ic an buy my monitor from any place and get it replace by HP....
I'm pretty sure Amazon has a "any reason" return policy. I'm not certain baout monitors, but I have returned other products with no issues simply because it wasn't what I was expecting. You do have to pay return shipping - I would think all places would require that.
RaptorKC, can you please do me a favor... by looking at the rev. number please.. Really do appreciate it...
GIG122
do you have to pay for shipping at amazon? newegg has it too...... or should I just go with provantage or pcnation... which one would you guys think have high turnover rate and best return polciy? regards.
You guys know of any B&M's carrying the LP2475W? I've checked and checked and come up empty but I'd almost be willing to drive an hour to Chicago to avoid the potential hassle of returning the monitor through shipping. That and I could verify the date code in store.
Do I also need to apply the 2475w .icc file in photoshop CS3 Extended? If not, what color profile should I select within Photo Shop?
Everything?
Also IE and windows pic viewer?
You need to apply the ICC profile for Windows so that the operating system assigns that profile to this specific monitor. Afterwards, all color-aware applications will use that profile. In fact, everything you see on your screen will be referencing that profile.
question:
i have an nvidia geforce 7600GT video card. would this card do justice to this monitor or to any 24"monitor?
thx.
After having this monitor for a while now, I've noticed that mine makes a very high frequency hissing-like noise. It's almost like being at a rock concert and when it's over you have temporary tinitus. It took me some time to figure out it's the monitor.
Lower brightnesses increases the sound's intensity. Brightnesses above 60 or so make it mostly go away. And after the monitor has wamed up for maybe 20 minutes, the sound's intensity decreases slightly.
Has anyone else noticed this? I can hear it from about 3 or more feet away but you may have to put your ear to the top or side of the monitor to hear it.
question:
thx.
There is sort of a fix for this. You just raise the brightness on the monitor until the sound goes away, then use the video card control panel to lower brightness back to a comfortable level.
That is not a "fix" for a 600 bux display... Looking for the eizo/lacie324/nec2490 now...![]()
I just ordered mine from Amazon for $620 +$4 for 1 day shipping (free trail of Amazon Prime), should have it Wed. the 28th![]()
anyone connect this monitor to a hdmi or component cable? If so what is the picture quality? and did you notice a flicker while plug in the component or hdmi cable?
FWIW my 2475 is perfectly quiet, and I'm quite sensitive to the high pitch noise you guys are talking about. Looks like it's luck of the draw.
HB
