The last motherboard I bought, and still use, is an Abit IP-35 Pro, which has a handy CLR_CMOS switch on the back IO panel. Whenever I shop around for motherboards I always try to keep an eye out for similar features, but only a few boards have them (at reasonable prices, that is---notably ASRock boards).
I feel like I may have been spoiled, because external buttons or switches seem to be pretty rare. But the absolute last thing I want to do is have to open up my case to set the jumper manually. I've looked through a few motherboard spec sheets searching for an easy BIOS reset feature, but those sorts of features are usually given stupid marketing names that don't even hint at what they actually do.
A way to reset my BIOS without resorting to needle nosed pliers is a required feature for me. So should I assume that all boards marketed to gamers or enthusiasts have a built-in BIOS reset feature, even if no physical button is present, or should I keep looking for IO panel switches for my next board?
