brom42 said:Plug the cable modem into a lamp timer. This works great if it is somewhere the kid can't get too. If you just want to restrict his, then plug his computer into a switch/hub and hook that up to the timer. This gives you total blocking power. Great because your kid can't play any online games or chat either.
Hawk001 said:Take everything any kid would want to do with a computer, out of it. Yet you still are paying. Is it just me or does this make no sence.
in three easy steps
1. copy this text into a notepad and save it as noaccess.rat
and save it in WINNT\system32 (W2K) WINDOWS\system32 (XP)
Code:((PICS-version 1.0) (rating-system "http://www.microsoft.com") (rating-service "http://www.microsoft.com") (name "Noaccess") (description "This file will block all sites.") (category (transmit-as "m") (name "Yes") (label (name "Level 0: No Setting") (description "No Setting") (value 0) ) (label (name "Level 1: No Setting") (description "No Setting") (value 1) ) ))
2. Open IE > Tools > Internet Options > Content > Enable > General tab > Rating Systems > delete all > add > noaccess.rat > OK > Approved Sites Tab > add
http://technet.microsoft.com/
http://update.microsoft.com
http://support.microsoft.com/
http://www.microsoft.com/windows2000
http://www.microsoft.com/windowsxp/
clicking "always" after each > General Tab > User Options > Check Supervisor can type password to allow users to view restricted content > uncheck Users can see sites that have no rating > set password
3. install Firefox with the noscript extention or Opera
IE is now secured
might make sense to restrict that folder's NTFS permissions as well
Program Files\Internet Explorer > Properties > Sharing Tab > check do not share > Security Tab > remove all users except yourself(Administrators)
