Shameless Liar said:1. Windows does not come with Media Player Classic
3. It's not in add/remove programs because it is a single .exe file.
Renswic said:ok now that we have gotten the 'useless replys that dont and will never help, from the pointless !!!!!!s' outta the way. lets get back to the problem of uninstalling it
1. my copy came bundled with it
2. if thats the case why does it still show after rightclick/open with i still show WMP and MPC in that menu and if i try to open anything(video or sound) it opens with it
You abrasive attitude, choice of language, grasp of the english language, and inablilty to comprehend forum rules with your > 10 line sig doesn't really spark much sympathy.Renswic said:it is a legal copy, i help out at a local computer shop here, they have started offering windows xp pro with some bundled softwere, i offered to test one of there "loaded setups" after installing windows(and entering the number on the COA sticker) you have the option on installing a number of both usefull and useless apps
that being said, could we possably get back on track and tell me how to uninstall MPC? i know it breaks all your hearts that i dont like it, but i dont i dare to be different
Menelmarar said:You abrasive attitude, choice of language, grasp of the english language, and inablilty to comprehend forum rules with your > 10 line sig doesn't really spark much sympathy.
With that out of the way.
Do this to help everyone out with exactly what media player you think is causing your problems. Goto the help menu, click about, and post a screenshot of the popup with version info and everything from your media player classic.
There can be a number of things on the context menu that are no longer installed on the computer. While an installer CAN install something to that reg key, it typically won't uninstall it from same. Also note that (IIRC), once you have opted to open a particular file with a program, that program will remain in the menu.Renswic said:2. if thats the case why does it still show after rightclick/open with i still show WMP and MPC in that menu and if i try to open anything(video or sound) it opens with it
FTW.Cheetoz said:How to Remove Programs from the "Open With" List http://support.microsoft.com/?kbid=258860
mpc is only a .exe and doesn't 'install' into the OS.
That kind of ignorant attitude thould get this thread locked.Renswic said:ok now that we have gotten the 'useless replys that dont and will never help, from the pointless !!!!!!s' outta the way. lets get back to the problem of uninstalling it
Renswic said:i dont see how my typing, spelling or grammer really effects the post
