I need more speed than 7200rpm
Thanks
If you get a physically larger hard drive that's also 7200 RPM, take the covers off so the platter is exposed. Then put your smaller hard drive on top (centered), turn them both on, and your hard drive's platter will be spinning at 14400 RPM.
Careful though, if you put it on upside down it will spin at 0 RPM.
Thanks
I need more speed...
Thanks
Ok, if you look at your sata power cable: you need to open that sucker up. Where there is orange, that is +3.3v, red is +5 and yellow is +12. You need to replace the orange with the red and split the yellow to also power where the red was. voila. over volting. I read about this on the internet that it was perfectly safe*. you can confirm by looking at this post: http://hardforum.com/showpost.php?p=1036594326&postcount=19
*Not responsible for any damage caused if this frys your computer or drive.
OP is on the right track, hard drives come bottlenecked from the factory. I recommend swapping the supercharger pulley for a smaller ratio, maybe 3.8:1 (compared to the factory 3.4). You will need additional cooling
