Monkeypillow
- Aug 30, 2006
I just received mine in the mail and don;t want to mess anything up. How far down do I need to push the tubing before tightening the compression?
Just until it touches the bottom. Then screw the fittings on for a snug fit. Don't over do it as you may regret it later if you find out you need to undo them for whatever reason (<- this happened to me, spent 3 hours trying to cut tubing up to unscrew it)
So push the tubing to the Bottom of the fitting, then screw the compression all the way so that the two pieces are flush?
Turn them with your fingers while holding them down with a tool?
I've tried that. The two pieces seem to want to stay together.
What are your fittings? Are they tapered or are they BSSP? What tube size is your compression fittings designed for?
I had the same problem. You just have to hold the two pieces tightly and wiggle them until they sort of loosen up and you should be fine.
Use the o-rings from a pair of the swiftech barbs that were included with the GTZ instead of the BP o-rings. Swiftech o-rings are thicker than the BP fittings, so they'll close the gap better. This is a problem plauging anyone that got the GTZ that doesn't use stock barbs.
Geez, still leaking and I can't even tightening anymore without fear of damaging something.
Hmmm... Don't get it.![]()
