Windows 7 happens after POST.
Unfortuneately, I do not recall any way to disable WIndows 7's scan of all connected devices, at startup.
Do you know the behavior I'm talking about? It never did it on my old, XP system.
you have a drive that "detects" if the system is on? abnd if the system is on, the drive turns on?
There is no way, that I know of, to prevent Windows 7 from doing it's little check of all drives.
Not exactly. My system saying the following during POST: "Auto-detecting USB Mass Storage Device. . ." Then it turns on the drive.
If you don't want the drive to function or wake up when you turn on the computer, unplug the damned drive. It's being detected as a drive by the BIOS routines and it's working as it should; this has nothing to do with the installed OS.
Was that really so hard?![]()
Autoplay is a Windows function, not a bios function. The issue the OP is talking about is related to his bios.
By the way OP, is "quick boot" enabled?
During post the OS has absolutely zero to do with what is going on.I have an external media drive connected. During POST, Windows 7 seems to want to wake up that drive and check it (I'm not sure why). Is there a way to turn that off? It would decrease my boot time by like 5 seconds.
