I replace it after each session of Crysis.
If your temps haven't changed in a year, I'd say leave it alone. I've got one that's 5 years old and the temps are still the same as the day I built it, and I don't plan on touching the paste. Why would I?![]()
I format my hard drive every 2 months, every time this is done I try to make sure that I replace the paste on my video card GPUs and my CPU.
I usually do it once every 2 years when I blow my pc's out with my air compressor.
Jesus dude, you only blow out your rig every 2 years ?![]()
To my knowledge none of the high performace ones suggest it. Unless you get into the exotic "liquid metal" stuff all of these compounds are a thermally conductive material (finely ground solid) suspended in an ester based oil. The oil is there for inital "flow" spreadability to allow the particles to migrate to the voids/gaps whatever you want to call them. Once that happens the oil is of no thermal use as it is the thermally conductive particles that do the work. So a dryed out appearance is not a problem if the stuff has migrated to where it needs to be. On the other hand once it does cure/dry out and you take it apart, you do need to reapply.
This is a generalization.
Doesn't it take a few weeks to cure...at least with WCing and no fan. So changing it too often wouldn't make the best tempretures anyway. Or I might be doing something stupid.
I dont know about you guys, I dont mind changing thermal paste, but its the push pin that get my balls hot. After about 2 changes, my plastic pin is broke. How do you deal with it?
Is that true if you get those Corsair radiator cooler, you dont need to use those push pin?
