What do you guys think I should upgrade first after i get my new heatsink ... http://i40.photobucket.com/albums/e240/jgbsnk4/Computer Cleanup/comp_stats.gif
Your computers IP address is 192.168.1.65
Your computers IP address is 193.169.1.66
I would get more memory to start off. Just that would be huge.
P£P§!™;1031392229 said:i knew that and thanks for sharing it with everyone else.
Wait wait, you now have a $1000 for this? If so, just build a whole new PC! It's simply more cost-effective to just build a whole new PC then try to upgrade your old PC, especially since your budget is now $1000.
Considering what you are doing now, I recommend going with this setup:
Intel Core 2 Duo E6750 CPU - $200
GIGABYTE GA-P35-DS3L Intel P35 Motherboard - $88
A-Data ADQVE1A16K 2 x 1GB DDR2 800 RAM - $78
Sapphire 100199L Radeon X1950GT 256MB PCI-E Video Card - $115
Seagate Barracuda 7200.10 320GB 7200RPM SATA 3.0Gb/s Hard Drive - $80
Samsung SH-203B 20X DVD±R SATA DVD Burner - $31
Corsair HX520 520W PSU - $105
Scythe SCNJ-1100P Ninja HSF - $36
Total: $737 Plus tax and shipping
Go on Newegg.com and find a computer case that you like. Cases are a personal choice item IMO so you should pick that out yourself. The above build outperforms your current rig by a large margin in video game. If you don't have a spare OS around, here's are two options:
Windows XP Home OEM - $90
Windows Vista Home Premium OEM- $100
The x1950GT should good enough for light gaming with your monitor's resolution. The 320GB hard drive is big enough for your graphics design needs. Though if you need to, you can easily add more SATA hard drives.
P£P§!™;1031392798 said:I think I should still use the same psu and will theat mobo u suggest still be able to run the video card i have now because i dont really want to upgrade that unless im gonna buy some badass 600 dollar one
P£P§!;1031392854 said:The psu I have is just a compusa brand 550, and yea the one that came with the case was crap it stopped working after 1 year of barely using the comp, and yea i did want to kinda save some money so i could possible sell my monitor now on ebay or something and get this one ive been looking at on Gateway
Nice. What a big help you are.
P£P§!;1031393210 said:Oh cool I think i will wait then and maybe pick up a 700 w it will just take longer than anticipated
If you're goin with that 24", then you'll need at least a single GTX or Ultra. However, you may want to wait for the new NVIDIA cards, which are rumored to be out in october.
Also, you'll need a new PSU to power the new vidcard.
P£P§!;1031393509 said:Unless your gonna be visiting Texas sometime soon you won't be finding me
BTW, was this the application you filled out for Fry's?
http://homepage.smc.edu/engfer_mark/frys.htm
...tell him they're empty boxes. If he picks one up to see, run
Invite him out to your car, where there's an 'Open Box Buy'
