How can you tell your SATA cable is rated at 6 Gb/s?
Discussion in 'SSDs & Data Storage' started by Happy Hopping, Oct 26, 2012.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,601
    Jul 1, 2004
    I was told some cables are only 3 GB/s, as it says so on the sticker of the cables.
    So if you buy a motherboard that c/w some SATA cables, the motherboard is all 6 Gb/s connectors, and yet the cables do not say whether they are 6 Gb/s cable, do you just believe that they should be 6 Gb/s cable?
    Likewise, w/ the red cable that c/w Intel's SSD, Foxconn 1152 G10333-001, E124936-B, should they be 6 Gb/s cable? As it doesn't say at all
  2. Bbq
    Bbq King of Charts
    12,272
    Feb 21, 2006
    is it a sata cable ?
    it's 6gbps.
  3. odditory
    odditory [H]ardness Supreme
    5,565
    Dec 23, 2007
    "SATA 6G" cables are being labeled and sold as such because it presents a marketing opportunity to take advantage of people that don't know better, and because there is literally no downside for suppliers and sellers to label them 6G - it costs them nothing and increases units moved by adding that pool of people thinking they're doing well to replace their old cables with "6G" cables.
    This is psychological contentment, nothing more.
    http://www.pugetsystems.com/labs/articles/SATA-cables-Is-there-a-difference-97
  4. drescherjm
    drescherjm [H]ardForum Junkie
    14,472
    Nov 19, 2008
    Exactly. All SATA cables are rated for 6gbs.
  5. Aesma
    Aesma [H]ard|Gawd
    1,844
    Mar 24, 2010
  6. danswartz
    danswartz 2[H]4U
    3,618
    Feb 25, 2011
    LOL. He'll probably want to sue the sata cable company for selling him the wrong kind of cable :)
  7. Metaluna
    Metaluna Limp Gawd
    393
    Jan 23, 2008
    I would write that as "All cables that actually comply to SATA specifications are good for 6gbps".
    I have no doubt there are cheap junk cables out there that just barely work at 3 gig, and which would have unacceptable error rates at 6 gbps (even then you probably wouldn't notice much difference without diagnostic equipment). The trick is telling them apart.
    There was a similar situation in the USB 1.1 to 2.0 transition. Theoretically a certified USB 1.1 cable was supposed to work at 2.0 speeds, but there were a lot of out-of-spec cables floating around, so it was worthwhile to look for cables that had the "Hi-speed certified" logo on them just to be safe.
  8. Cheetoz
    Cheetoz [H]ard|Gawd
    1,972
    Mar 3, 2003
    Would be nice if someone did a benchmark on typical SATA cables, and the maximum rates they can handle before the signals break down.
  9. Old Hippie
    Old Hippie [H]ardness Supreme
    6,013
    Oct 31, 2005
    LOL!
    Sad but true. :eek:
  10. drescherjm
    14,472
    Nov 19, 2008
    This link did that on a very limited bases:
    Although since there was no problems for the test SATA II cables transferring at SATA III speed there was no way to see what speed the cable broke down. Perhaps if there was some SATA IV interface and device to test..
  11. MrD1234
    MrD1234 Limp Gawd
    229
    Jul 10, 2010
  12. mwroobel
    mwroobel [H]ardness Supreme
    4,942
    Jul 24, 2008
    We really should make this a sticky. All SATA cables, IF MADE TO SPEC, are compatible from 1.5 to 6.0 Gb/s. The ones with the metal retaining clips are less apt to fall off. That is all.
  13. blastingcap
    blastingcap Gawd
    682
    Nov 5, 2009
    http://www.maximumpc.com/article/fe..._down_your_data_transfers_max_pc_investigates
    "The official word from the SATA International Organization is no, not at all. The SATA I/O lays it out in its FAQ:
    “Question: Does SATA 6Gb/s require different connectors and cables to support the higher transfer speed?
    Answer: The same cables and connectors used for current SATA 1.5 and SATA 3.0 Gb/s implementations can be used to connect SATA 6Gb/s devices, although SATA-IO recommends quality components be selected to ensure data integrity and robust operation at the faster SATA 6Gb/s transfer rate. Keeping the existing SATA connector form factor enables SATA 6Gb/s to be designed into the same cost-conscious hardware architectures while minimizing infrastructure changes.”
    Every single SATA cable they tested was basically the same speed.
  14. Happy Hopping
    6,601
    Jul 1, 2004
    see, I have a bunch of SATA cables, there is a sticker that wraps around the SATA cable says 3 GB/s
  15. XacTactX
    XacTactX [H]ardness Supreme
    4,103
    Dec 13, 2010
    +1 Here's another article to drive the point home: http://www.maximumpc.com/article/fe..._down_your_data_transfers_max_pc_investigates
  16. MatDef
    MatDef [H]ardness Supreme
    4,706
    Nov 15, 2005
    [​IMG]
    Applies again.
