justaguy_99
- Dec 5, 2006
e6600
evga 680i
evga 880gtx
stock cooling
So I bought the components for my rig last spring and put them all together without much though about overclocking until later. Tonight I get the fever, so I fire up the BIOS and start playing settings, get to about 2.9 Ghz and realize that I'm running pretty hot at idle already (~60 C). I'm kinda miffed because these cpus are supposed to be able to handle around 3.2 on stock cooling I thought? So I play around with some settings, and get it down to 55 C, but this is still pretty hot for a pretty weak OC. Now I'm getting suspicious so I reset everything to default and let it idle for about 10 minutes, and see that it's idling at 57 C! Wtf? Not only that, but at full load, it climbs up to about 72-74 in just a few minutes. Did I get a shitty cpu? Do I need to lap this thing just to get it to perform at normal expectations? I've already cleaned off and reseated the cpu with artic clean and as5. What gives?
Thanks,
Steve
P.S. nTune after default reset:
evga 680i
evga 880gtx
stock cooling
Thanks,
Steve
