Wow, talk about a PITA.... after running a 3043 to 7% 3 times for the fail, I just got another 2653.
What a waste of an hour!
I don't understand how you people get such high PPD values with a single quad when I'm struggling to get 5000PPD with a dual quad and the new WUs.Well, I set up a dual smp, and to my dismay..... I downloaded a pair of 3060's. However, it looks like I may come in at 23 hours which could mean a 5k + day for the quad.![]()
What's your setup exactly? Frequency, OS and number of clients?For some reason unknown to me, my quad folds larger proteins faster.
It takes about 17-18 hours on average for a 2653. Yesterday I knocked out a 3050 in 16 hours.
Obviously you're doing something right if your machine is at par with an 2.8GHz 8-core server also running XP.Oh, and just for the record.... I don't know what the hell I'm doing.![]()
Ice, it hasn't made a difference in my clients and I switched all of them to type 0. I think it will only make a difference if you're either running dual-core systems or VMs, not quads or higher, unfortunately.I should probably drop the advanced flag also. Last thing I need is instability going into this race.
I see. No one mentioned this before. How do I go about changing the UID? Registry?One trouble is that you tend to get sent back to the same server you last used, untill that server runs out of work-units.
Which is why you tend to have strings of good & bad work units.
One way around this is to shut down just after you've uploaded your latest work unit and before you download your next.
Then remove your UserID number.
