KazeoHin
- Sep 7, 2011
I think this has been said before, but this only works on issues relating to soldering. If the problem is corrupt RAM or just bum silicon, you'll only do more damage.
Try woodwhat else could i use that is cheap and handy to support the card so it doesnt physically touch anything hot inside the oven? its not like the foil was touching any sensitive electronic parts...
Just an update to my post #1126, my card just died. Lasted a lot longer than the few days i was expecting it to last , just over 5 months. I'll probably buy another card this time around.I stumbled across this thread accidentally after buying a PNY 8800GT from ebay that was faulty. The guy stated it became faulty after a driver update so i assumed i'd install the proper drivers on my PC and i'd be off. Of course, that wasn't the case. Dots and stripes at startup and card would get stopped once Windows was up and running.
I did the bake today; 9 minutes and now the card works I played Black Ops/Zombies for a bit at full resolution and it worked flawlessly. I'm upgrading from a 8400GS (i'm not a big gamer) so the graphics improvement is very impressive The card stated it's RoHS as well whic his good (the end part of the PCI-e section with no metal stripes).
A question for those who baked their cards a long time ago; has anyone's card become faulty again?
Linksys WMP300N
Now working!!!
Haste266, is your card still working? Or have you upgraded since? (as the threads over 2 years old now).
Another update. I wasn't keen on putting the 8800GT back in the oven, but i don't have any other graphics card and the card being disabled due to the fault causes major slowdown of my PC. So yesterday i thought i'd give a hair dryer a try (don't have a heatgun), held it for a while on the gpu, memory and around the card and shockingly the cards working now So far a whole day, although not played any games. Surprised it came back to life as i didn't think a hair dryer would produce enough heat, but i'm guessing it won't last as long this time around and the over trick would no doubt make it last longer.Just an update to my post #1126, my card just died. Lasted a lot longer than the few days i was expecting it to last , just over 5 months. I'll probably buy another card this time around..
I think the reason the hair dryer worked for me is because originally i did the oven trick and the card lasted 5 months, this time around didn't use the oven trick as i ordered a new card instead and thought i'd see if i could jolt the faulty card back to life temporarily until the new card arrives.Neat. The oven didn't work for my 8800GT, either. I'm going to try my propane torch. Your experiment has given me hope that it can be revived.
you reflowed the solder but unless you used some sort of flux it won't be a permanent fix.
