Hmmm....what to upgrade?
Morphx2
Well, its almost time for my 2-year upgrade...so what should I upgrade? CPU, RAM, MOBO, or GPU? Or all of them! Mainly used for gaming and noticed games like DC Online Universe was acting choppy and sluggish during the beta, and i cant have none of that!
Gaming
Cheaper the better, but want a good bang for the buck. DEFINATELY under 400 (cant have the wife get mad!). 300 is would make me a happy camper too, but doubt that is possible :p
3) Where do you live?
Boring New Mexico (Hobbs, NM)
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Mobo, CPU, RAM, GPU, even power supply maybe?
Here is what I have now:
1 x GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard
1 x PowerColor AX4830 512MD3-H Radeon HD 4830 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
1 x CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply
1 x Intel Core 2 Duo E7400 Wolfdale 2.8GHz LGA 775 65W Dual-Core Desktop Processor BX80571E7400
1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
6) Will you be overclocking?
Nope
1680 x 1050, i forget the exact size
Probably soon
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
One that can support my old PATA DVD drive and at least 2 of my SATA HD's
Already have Windows7 64-bit
Thanks in advance!
You don't need an upgrade at all. If you reallllly want to, you can upgrade that video card (and possibly the PSU, depending on what you do for a video card). C2D is perfectly good for gaming and you will gain almost nothing by upgrading it. All the gamers here that are upgrading CPUs all the time and running 20GHz 32-core machines are just wasting money. Those sorts of machines are for digital image/video/whatever processing...
I have to disagree with most of dandragonrage's entire post. I noticied an immediate difference moving from a dual-core E6400 OC'd to 3.2Ghz to a tri-core Phenom II X3 720 OC'd to 3.6Ghz in BFBC2, FO3, and Eve Online. So yes there are great gains to be had by upgrading the CPU + mobo + RAM to a newer platform. A C2D is only "perfectly good for gaming" if the performance you're getting from that CPU is actually acceptable to you. If it isn't, then it's not "perfectly good for gaming"
With that said, your best bet for an immediate and noticeable upgrade would be a GPU upgrade. I don't know what games dandragonrage are playing but the HD 4830 512MB does struggle with many newer games out there, expecially ones at 1680x900 or above. So yes, you do need to upgrade that video card unlike what dandragonrage said.
So here's what I recommend:
$195 - XFX HD-685X-ZDFC Radeon HD 6850 1GB PCI-E Video Card
$73 - Antec NEO ECO 620C 620W PSU
Total: $268 plus tax and shipping.
Yes that is a new PSU but it'll give you more headroom for a future CPU+mobo+ RAM uprade as well as stresses the PSU a whole lot less.
Thanks for the suggestion Danny.
I think I will buy one of the 6850's on amazon because I recently sold a book I used in grad school 3 years ago for around 150 bucks :D As soon as they get the book, I will go buy the card :D
Power Supply isnt that expensive either, so I will probably pick that up too
Thanks for the help!
No prob.
