Absolutely!nice.. i want to see 8 projects at one time in action on that thing.. screenshots damnit! with temps![]()
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
11901 jt 39 19 1049m 706m 1540 R 100 12.0 8:32.12 garli_5.15_i686
11896 jt 39 19 1049m 713m 1544 R 100 12.1 8:31.79 garli_5.15_i686
11897 jt 39 19 1049m 713m 1544 R 100 12.1 8:30.68 garli_5.15_i686
11899 jt 39 19 1049m 710m 1540 R 100 12.1 8:31.27 garli_5.15_i686
11902 jt 39 19 1049m 710m 1536 R 100 12.1 8:32.40 garli_5.15_i686
11898 jt 39 19 1049m 709m 1540 R 98 12.1 8:32.62 garli_5.15_i686
11900 jt 39 19 1049m 706m 1540 R 75 12.0 8:31.43 garli_5.15_i686
Sorry, but SpeedStep is on for a reason.Make sure you disable Intel SpeedStep in the BIOS or the OS will slow your cores down... and disable the screen savers and disable sleep/hibernation and power always on - type things...
I'm looking into it, but the project or BOINC may not agree with HyperThreading.
I currently have it enabled and the clock doesn't drop below 2.67GHz while under full load. In addition, I'd really prefer the CPU to have the ability to downclock itself if the heat became intolerable. Crunching would be moot with a damaged CPU.That reason is a moot point if you are DC'ing.![]()
Which is another reason the feature is still enabled; I may or may not be crunching 24/7.no sense in having a cpu running at 2.67ghz per core when the systems doing absolutely nothing..
For the record, that happens even if Speedstep is off (the CPU's thermal protection features are always active, no matter what). I do think that Speedstep should be left on though.In addition, I'd really prefer the CPU to have the ability to downclock itself if the heat became intolerable.
Thanks to everyone for clearing that up for me.For the record, that happens even if Speedstep is off (the CPU's thermal protection features are always active, no matter what).
Needless to say, I agree.I do think that Speedstep should be left on though.
