Aug 26, 2007 #1 D Dynafrom Gawd Joined May 28, 2006 Messages 628 Got a new mobo (p5n32-e plus sli mobo) and it displays no power on boot. I removed all system parts that were unnecessary, except videocard, ram, cpu. Still no luck, I know the parts before worked. Any help?
Aug 26, 2007 #2 Nenu [H]ardened Joined Apr 28, 2007 Messages 20,314 Does the green LED light up on the motherboard when the psu is plugged in?
Aug 26, 2007 #4 kirbyrj Fully [H] 2FA Joined Feb 1, 2005 Messages 31,350 What power supply are you running? Did you try with only 1 stick of memory? Does it run outside the case? Possible case short? What did you change from when it worked before?
Aug 26, 2007 #5 D Dynafrom Gawd Joined May 28, 2006 Messages 628 Ok, board is dead. I just swapped it, and all the stuff worked.
