Help with GA-965P-DS3P Overclock Voltages
stone2
Hi all, I have had my current setup for about a year now and I followed this guide (http://www.hardforum.com/showthread.php?t=1169366) to do a basic overclock and everything has been fine. The other day I decided to up the overclock and I got 3.2GHz out of my E6420 without adjusting any voltages.( I didn't adjust any voltages for the first overclock either) I am wondering if I should be grateful I didn't have to up any voltages or worried that I should. I have run Prime 95 and Orthos for a couple of hours each and had no problems. I am running the cpu at 8 x 400Mhz.
Here are some CPU-Z screenshots:
http://i246.photobucket.com/albums/gg105/stone2_photo/SPDOverclock.jpg
http://i246.photobucket.com/albums/gg105/stone2_photo/MemoryOverclock.jpg
http://i246.photobucket.com/albums/gg105/stone2_photo/CPUOverclock.jpg
Regards to all
GigaByte GA-965P-DS3 Pro
Core 2 Duo E6420 OC @ 3.2GHz
2 Gig Corsair XMS 6400C4
3 x Seagate 320 GB HDD
1 x WD 500GB HDD
1 X WD 200 GB HDD
Point of View Geforce 8800GTS 320MB OC @ 600x900
Creative Audigy 2 Sound Card
Leadtek TV2000 XP Deluxe TV Tuner
NEC DVD_RW ND-3500AG
PSU-Enermax NoiseTaker II 420 Watt
What is the voltage is that CPU set at? Oh and you should be grateful. :D
However, I recommend running Orthos for at least 4 hours or a full 24 hours if you really want to make sure that your OC is stable.
Be glad you don't have to raise voltages. Raising voltages means a hell of a lot more heat. The less you have to raise your voltage to get a stable overclock, the better.
Also, as mentioned, a couple of hours of Orthos or Prime are not enough to judge real stability. I would consider 12 hours the absolute minimum but prefer 24 hours myself.
i wouldn't call orthos the all-supreme test of stability, I was running 3.6 @ stock v and orthos ran for hours without a problem, but when rendering a 3d scene for 40minutes it would bluescreen :p had to up it .05v to 1.25 to stabilize it maybe I should write a proggy to load all 4 cores that way 0.0
but yea you should be happy I had the same deal with my 6420 and 680i sweet deal imo!
CPU-Z says the cpu voltage is 1.312 (check the screenies).
Well to all those that replied a big thnak you for your help
