- Dec 3, 2006
Hi everyone, I hope you could help me with a problem I'm having currently. I just bought an ASUS ul80vt but unfortunately it doesn't come with a DL dvd. I bought a DL dvd drive from microcenter: model LG GH22NS40 and hooked it up via USB. I have used imgburn before with this drive and burned DVDs fine. I have tried 2.4X and same error. When i try to burn a dual layer (with verbatim media) it says: set L0 Data zone capacity failed! Reason: the semaphore timout period has expired (whatever this means) I push cancel and it pops up another error: DeviceIoControl (IOCTL_CDROM_EXCLUSIVE_ACCESS, Unlock) Failed! Device _____ (my device) Unable to unlock volume for exclusive access. Reason: Access denied.
I 22:51:22 ImgBurn Version 2.5.2.0 started!
I 22:51:22 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7600)
I 22:51:22 Total Physical Memory: 4,158,488 KB - Available: 2,735,092 KB
W 22:51:23 Duplex Secure's SPTD driver can have a detrimental effect on drive performance.
I 22:51:23 Initialising SPTI...
I 22:51:23 Searching for SCSI / ATAPI devices...
I 22:51:23 -> Drive 1 - Info: HL-DT-ST DVDRAM GU10N MR03 (E
(ATAPI)
I 22:51:23 -> Drive 2 - Info: HL-DT-ST DVDRAM GH22NS40 NL02 (G
(USB)
I 22:51:23 Found 2 DVD±RW/RAMs!
I 22:56:48 Operation Started!
I 22:56:48 Source File: D:\*********************************************(ommitted what I was burning just in case it violates the rules)
I 22:56:48 Source File Sectors: 3,827,488 (MODE1/2048)
I 22:56:48 Source File Size: 7,838,695,424 bytes
I 22:56:48 Source File Volume Identifier: DVD_ROM
I 22:56:48 Source File Volume Set Identifier: 356fc000MS UDFBridge
I 22:56:48 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
I 22:56:48 Source File Implementation Identifier: Microsoft CDIMAGE UDF
I 22:56:48 Source File File System(s): ISO9660, UDF (1.50)
I 22:56:48 Destination Device: [0:0:0] HL-DT-ST DVDRAM GH22NS40 NL02 (G
(USB)
I 22:56:48 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 2.4x, 4x, 6x, 8x, 10x)
I 22:56:48 Destination Media Sectors: 4,173,824
I 22:56:48 Write Mode: DVD
I 22:56:48 Write Type: DAO
I 22:56:48 Write Speed: 4x
I 22:56:48 Link Size: Auto
I 22:56:48 Lock Volume: Yes
I 22:56:48 Test Mode: No
I 22:56:48 OPC: No
I 22:56:48 BURN-Proof: Enabled
I 22:56:48 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 22:56:48 Book Type Setting: DVD-ROM
I 22:56:48 User Specified L0 Data Zone Capacity: 1,913,760
W 22:57:11 Device Removal Detected!
W 22:57:11 The device list will be refreshed at the next available opportunity.
E 22:57:59 Set L0 Data Zone Capacity Failed! - Reason: The semaphore timeout period has expired.
E 22:59:50 Failed to unlock drive from exclusive access.
E 22:59:50 Reason: Access is denied.
E 22:59:50 Operation Failed! - Duration: 00:01:11
I 22:59:50 Average Write Rate: N/A - Maximum Write Rate: N/A
I 22:59:51 Searching for SCSI / ATAPI devices...
I 22:59:51 -> Drive 1 - Info: HL-DT-ST DVDRAM GU10N MR03 (E
(ATAPI)
I 22:59:51 -> Drive 2 - Info: HL-DT-ST DVDRAM GH22NS40 NL02 (G
(USB)
I 22:59:51 Found 2 DVD±RW/RAMs!
Please help! anything would be helpful! If there is any additional info you need, I'd gladly provide it. Thanks for helping
I 22:56:48 OPC: No
