1) Figure out your budget: Max $1000 due to customs restrictions
2) Figure out which components you would need for your setup.
I need, CPU, motherboard, Ram, PSU, Monitor, videocard.
3) Determine what the computer is going to be used for:
Mostly gaming with photo/graphics editing and light video encoding, 3 or 4 divx movies a week that take around 40mins each on my Athlon 4200+.
4) Figure out which features you want on your computer: Don't need raid nor have a lot of hard drives. Only need a couple sata ports, one IDE and the PCIX16X
5) Determine whether or not you are planning on overclocking any of the components. Well both videocards I've overclocked even a tiny bit have ended up dying on me... last CPU I overclocked was a good ol' Athlon 2500+ unlocked. I guess if I get a good cooler and there's a good performance gain I could risk it.
6) Determine how long you want your machine to last. Machine will need to last at LEAST 2 years. It's not easy for me to obtain new PC parts since I don't live in the US.
7) DO SOME RESEARCH. I have been reading these boards several times a day for about a while now and read a lot of reviews.
8) Come up with a list of what you want:
Intel Core 2 Quad Q9550
Combo GIGABYTE GA-EP45-UD3R
PNY VCGGTX260XPB GeForce GTX 260
Combo with Thermaltake W0106RU 700W
OCA Reaper 4gb PC2-6400
Artic Cooling Freezer 7 Pro
Asus 22'' LCD
Total Newegg $1049, minus $105 in possible rebates. free shipping on everything
Will the AC 7 Pro fit with the OCZ reaper's tall heatsink/pipes? On the newegg reviews seems some people aren't getting that $50 rebate on the PSU.
or from Amazon:
Gigabyte GA-EP45-DS3L
Ocz 500W Stealth Xstream Psu
OCZ OCZN800SR4GK 4 GB Kit 800MHZ DDR2 PC2-6400
MSI N260GTX-T2D896-OC GeForce GTX 260 896MB
Acer V223-WBD 22" Widescreen TFT LCD Monitor
Total from Amazon $958.36 minus $85 in possible rebates, free shipping.
I guess the PSU on the amazon build is kind of weak maybe I could change the OCZ for a Antec Neo-HE-500 500-Watt
I couldn't find the AC7 in amazon and I have no idea which cooler could work, OCZ Vanquisher? OCZ Vendetta? Any recommendations on improving either build? I know the Amazon one needs a lot of work but since its coming a bit under budget I could fit an extra $50 on PSU/Motherboard upgrades.
9) Figure out where you are going to purchase everything from.
Newegg or
Amazon, Buy.com
(Newegg doesn't accept international credit cards so I'd have to pay by check and I'm not so trusting of the postal service. Amazon and Buy.com do accept international credit cards)
I've always used generic "el cheapo" PSU's without problems but I think I'm gonna go for a good PSU for this build. My main issue is debating whether the Q9550 is enough of a long/short term upgrade over the E8500 to warrant the extra $130. Ive seen some benchmarks in which it smokes the 8500 but in some games the 8500 gains the advantage. I'd be willing to live with a small decrease in performance in some games to have more long term computing power.
I deeply appreciate any advice.
Asus 22'' LCD
or from Amazon:
Newegg or
Amazon, Buy.com
