Dear [H] Members,
I have set aside a little tax money for some upgrades to my new rig. I have maybe a little over $500 to throw at it. (I could squeeze a little more by selling current components, too).
Firstly, I am almost certain I want that new full-tower case Corsair is going to make, assuming it really materializes in May on shelves (unless you can suggest a similar performing/featured unit with as good of cooling and cable management options at similar or better price...)
There goes $250, I'm guessing, on that. Now, Dell has that Q9550 for $240!!! That would be a nice upgrade to replace my Q6700 with. Better temps and quicker performance with less voltage. That would be quite a decent upgrade, and would work great probably on my P5Q pro or my 780i EVGA board.
But, I could sell the Q6700, P5Q Pro, and the 780i and use that money with my tax refund to buy an x58 board, 920 processor, and some RAM. These are the boards I'm considering (not in any special order):
1. EVGA
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188046
Main appeal of this board is that I like the layout, and the $250 AR price. Performance, stability and overclocking reviews are largely solid on this one. The one limiting factor is that Anand mentioned that it can't do 1600 on RAM with the 920 processor for some reason, and I think the Asus and Gigabyte models can ... correct me if I'm wrong.
Edit: Turns out the memory problem is corrected in current BIOS, and this cheaper model has no lifetime warranty. No more price advantage.
2. Gigabyte
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128362
All hail the mighty UD5! This board has lots of high praise, and while more expensive still has a good layout and overclocks well. It's ugly (I like black PCB) but if this is really what my money should be spent on let me know. It's here on my short list and boasts good features and expandability. I have had one bad experience with their customer service - or lack of it. But I believe overall they make solid boards.
3. Asus
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365
This one got Anand's Editor's Choice gold award. They liked the BIOS, it overclocked well, and had great stability. My many experiences with Asus have met or exceeded all expectations, including phone support, having them send me a rebate check even when I mailed the form in late, and being able to hit 4.0GHz Vista stable on my Q6700 on air with my P5Q Pro. Love my Asus board!
This is the RAM I'm thinking of using:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
Fair timings, 1600MHz, solid brand, and price seems good right now for 6GB.
There's also this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
Better timings and same price after rebate.
So what do you guys advise? I really don't know what to do. Get the Q9550, new case and call it good? Or sell a bunch of stuff and go i7? I game a lot, and will be doing a lot of HD video editing, as well as using CS4 extensively for design and photo editing. I am an extreme multitasker as well, and will use Vista 64 bit on my primary rig for sure, eventually win 7.
I welcome and request your wisdom!!
1. EVGA
2. Gigabyte
3. Asus
There's also this:
