investinwaffles
- Apr 26, 2010
Whats up guys?
I want to build myself an Media Center/server combo but I am kind of lost. I am pretty terrible with networking
Basically, its going to be next to my TV in the living room and I want it to be an HTPC, as well as a media server. I dont want to keep my gaming rig on 24/7, and I want to be able to access my media library on my TV (now I have to dump things on a flash drive and plug my laptop in).
Will windows home server do all of this for me? And can my roommate's apple laptops connect to the media server somehow?
HTPC/Media Server use. 1080p MKV's + Bluray playback + DVR Features (tv tuner).
~$400 ish tax + shipping included, excluding all software
3) Where do you live?
Bolder, CO 80303
Case, Mobo, CPU, Ram, HDD, PSU, and a SILENT cpu cooler. Bluray Drive and TV Tuner will be added in as I can afford them.
Only part that I may re-use is an ATI 4850 if it is even needed.
6) Will you be overclocking?
Yes, if needed. If not, ill undervolt to make it as quiet as I can.
42" Panny Plasma, 1080p
Within the next month, I can wait for black friday/cyber monday I guess.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Onboard HDMI + Sound capable of HD playback
Vista Business 64bit or Windows 7 32bit
Prelim build I put together in 15mins for around $450, how could I compromise to lower the price, but still not have to upgrade any of the core hardware for a long time?
Is this build powerful enough for HTPC use (1080p mkv's + bluray's)? The MOBO has an AMD 785g Chipset (ATI 4200 integrated graphics). I decided to spend some extra coin on a nice ass case (with good hdd cooling), and probably overboard on the PSU.
I will be adding (as I need, and can afford them) a bluray drive, tv tuner, and multiple HDDs as I need them.
What would you guys do in my situation? Does this sound like a good option (the build above, coupled with WHS)?
Is my build way overpowered (i would like it to be running 24/7 so power is a concern)? I was looking at some of the 45w AMD processors, but I am unsure if they are worth it (only $30 to upgrade to the Phenom II x3).
I went with the Phenom II X3 so I could have enough power to do things in the background such as recording cable, torrenting, etc but will playback be smooth at 1920x1080 with just the integrated graphics?? Also, would it be a better idea to have a desperate OS drive for the WHS machine such as 80gb OS drive, 2tb Storage drives??
I will probably unlock the 4th core and undervolt unless I need the speed (then I will overclock).
I also have my old 4850 that I can stick in there, but I would really prefer not to due to power use and heat.
Sorry for all the questions, i am just a little lost! Any help would be greatly appreciated!!!
Bolder, CO 80303
Code:
Antec Mini P180 White Steel MicroATX Mini Tower Computer Case
Item #: N82E16811129044 - $80
Western Digital Caviar Green WD20EARS 2TB SATA 3.0Gb/s - $90
OCZ ModXStream Pro OCZ700MXSP 700W - $55
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) - $40
AMD Phenom II X3 715 Black Edition Heka 2.8GHz Socket AM2+ 95W Triple-Core
GIGABYTE GA-MA785GM-US2H 785G HDMI Micro ATX AMD Motherboard - $120 for the combo
Used Thermalright TRUE with some silent fan - $35
Total: $450 + shipping
