I launched Guild Wars 2 and was only getting 8-9fps, and decided to check the CPU temperature while trying to figure out what was wrong. I almost did a double take when I looked at what CPU-Z was reporting, so I restarted the computer and went into BIOS to check the temperature there. This is what I was greeted with:
Now, I have always had some trouble with my HSF (CM Hyper 212 Plus) as discussed in my PC build thread from November. The Hyper 212 obstructs one of the RAM slots on my mobo (MSI P67A-GD55), and I cannot comfortably use slot #1 (currently using slots #2 and #4).
I remember needing to reapply the thermal paste and reattach the HSF one month after I bought it because the idle temperatures were higher than they should be (but still within safe range, unlike now). So yeah, 96C idle is crazy, and this seems like a good opportunity to replace my HSF. I don't know if my existing one is faulty, but I'd much rather buy a different model to also resolve the RAM slot obstruction issue.
What is a good (and preferably not too wide) HSF to replace the Hyper 212 with? I'm considering the Zalman CNPS9900MAX, as it seems to have a plethora of positive reviews everywhere. I'm not overclocking these days, but I'd like the HSF to be able to handle it if I choose to. I perform a lot of CPU intensive operations such as playing MMOs and running concurrent simulations of different search trees. I need the HSF to be able to keep my 2600k at decent temperatures during such activities.
