Help building midrange SFF
FerraraZ
PC Gaming
Web Browsing
Home Media Server/Center (sharing network drives)
$800-$1000 Ordering from Newegg so whatever tax and shipping come to
USA
CPU + CPU heatsink
DVD Drive
Video Card
Hard Drive
Case + Power Supply
Motherboard w/ Wireless Internet (or some WiFi solution)
DDR 3 PC3 12800 OCZ Reaper HPC Ram / 8-8-8 @ 1.65v (8 Gigabytes of it)
6) Will you be overclocking?
No
1900x1280
October 28th, 2011
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 is a plus, SATA 6Gb/s is a plus, onboard wireless is needed
Yes Windows 7 64bit Ultimate
WAY too much for that hdd, go with the samsung 1tb instead pretty much the same performance and cheaper.
Get a ssd.
If you are not overclocking I would go with an itx mobo and case, it will be smaller since thats what you are looking for.
Depending on what he's doing in the realm of media I could see an ITX system being okay but if the OP wants any expansion capabilities I can't see that being very feasible.
mATX vs ITX really depends on how small the OP wants their system to be. Even with an ITX system, for drive expansion you could always get a NAS; for TV Tuner you could go USB and/or Ethernet (HD HomeRun); so an ITX system isn't really that limited in terms of expansion capabilities, unless you want some SLI/Crossfire action, lol.
@OP, your RAM is pretty high voltage for an Intel setup.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112265
Only $110 and you can put 6 hdd's in that. If he needs expansion cards then that's different but he only mentioned media/file sharing.
Yah, too bad only a few mini ITX boards offer 6x SATA ports. :(
Newegg public wish list saved as sff[H]
APEVIA X-QPACK2-NW-BK/500 Black Aluminum Body/ Front Mask MicroATX Desktop Computer Case 500W Power Supply
Model #:X-QPACK2-NW-BK/500
Item #:N82E16811144140
In Stock
$94.99 -$10.00 Instant $84.99
Seagate Barracuda Green ST1500DL003 1.5TB 5900 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:ST1500DL003
Item #:N82E16822148725
In Stock
$79.99 $79.99
Rosewill RNX-N180PCe PCI Express Revision 1.1 Wireless Adapter
Model #:RNX-N180PCe
Item #:N82E16833166063
In Stock
$24.99 $24.99
SAPPHIRE Vapor-X 100315VXL Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
Model #:100315VXL
Item #:N82E16814102953
In Stock
Mail in Rebate Card14-102-953
$169.99 -$5.00 Instant $164.99
Open Box: ASUS P8P67-M (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Model #:p8P67-M (REV 3.0)
Item #:N82E16813131708R
In Stock
$129.99 -$16.00 Instant $113.99
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Model #:BX80623I52500K
Item #:N82E16819115072
In Stock
$219.99 -$5.00 Instant $214.99
LG Black Blu-ray Drive SATA Model UH12LS28 OEM LightScribe Support - OEM
Model #:UH12LS28 OEM
Item #:N82E16827136232
In Stock
$69.99 $69.99
OCZ Vertex 3 VTX3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
Model #:VTX3-25SAT3-120G
Item #:N82E16820227706
In Stock
Mail in Rebate Card20-227-706
$299.99 -$100.00 Instant $199.99
Subtotal: $953.92 <<<<<<<<<<<<<<<<<<<<<!!!!!!!!!!!!!!!!!!!!!!!!!!
$190 - Intel Core i5-2400 CPU
$158 - Gigabyte GA-Z68MA-D2H-B Intel Z68 mATX Motherboard + Corsair Vengeance CMZ8GX3M2A1600C9B 2 x 4GB DDR3 1600 RAM Combo
$280 - XFX HD-695X-CDFC Radeon HD 6950 2GB PCI-E Video Card
$118 - Hitachi Desktar 7K1000.C 0F10383 1TB SATA 3.0Gb/s Hard Drive
$18 - Samsung SH-222AB SATA DVD Burner
$106 - SeaSonic M12II 620 Bronze 620W Modular PSU
$40 - D-Link DQA-556 Xtreme Desktop Adapter PCI-E x1 (use promo code EMCJKHC53 to get it to that price
Total: $910 plus tax and shipping.
Case wise, choose your own case. I recommend any of these:
$70 - NZXT Vulcan mATX Case
$85 - Silverstone SUGO SG02B-F Black mATX Case
$100 - Silverstone TJ08B-E mATX Case
$110 - Lian Li PC-V351A Silver mATX Case
$110 - Lian Li PC-V351B Black mATX Case
$125 - Lian Li PC-A04B Black mATX Case
$126 - Lian Li PC-A04A Silver mATX Case
$140 - Lian Li PC-V354A Silver mATX Case
$150 - Lian Li PC-V354B Black mATX Case
Also, do not go with the Apevia case that uunut linked to because it's bundled with a really shitty power supply.
The TJ08-E is a really nice case. If you want something smaller, the SG02 is good.
How much space do you need for your media? I'd suggest at least a 2TB drive, but I'm not sure about your usage, so... it really depends on what you plan on storing.
